Hi, please excuse me, but I am new to PC3000. This drive was, I thought dead, because I
could not get it to spin up. Using a perfect donor, we tried hot-swap with no luck, but at
least the drive spins up now. But the size and ID are wrong. (see below)
I would like to know how to use the PC3000 UMMA to fix this drive.
I tried to also attach the log and results of SA Structure test, but this app. would not let me.
So, please excuse my long paste:
LOG-----------------------------------------------------------------------------------------------------------------
Techno mode key
RAM:
Zone allocation table................... : HDDs RAM reading error - Drive is not ready
SA SPT.................................. : 853
Head number reading..................... : Ok
ROM:
ROM version............................. : 21.20E
ROM generation.......................... : 21.20E
Link table version...................... : 02.20.
Head map................................ : 0,1,2,3
ROM Firmware version.................... : 00210020
Service area:
SA dir reading.......................... : Ok
SA Copies avalabled..................... : Copy 0,Copy 1
Configuration reading................... : HDD ID Structure error (PSW Access)
SA Firmware version..................... : 00210020
Read ROM
Into file............................... : <HDD Profile>\Data\ROM\ROM.bin
Ok
Read ROM modules
Module : 0A............................. : Ok
Module : 0B............................. : Ok
Module : 30............................. : Ok
Module : 47............................. : Ok
Module : 0D............................. : Ok
Heads test
Cylinder to test........................ : -10
Heads to test........................... : 0,1
Head 0.................................. : Ok
Head 1.................................. : Ok
Heads test
Heads to test........................... : 2,3
Head 2.................................. : Ok
Head 3.................................. : Ok
---------------------------------------------------------END LOG---------------------------------------------------------------------
-----------------SA STRUCTURE TEST-------------------------------------------------------------------------------------------------
Id :Copy: Importance: ABA :Size:Read : Hdr : CS : CS Value: Vers. : Desription
0110: 0 : B : 60122: 24:Yes :Error:Error:0000/00BD:........:Modules directory (base part)
0110: 1 : B : 60122: 24:Yes :Error:Error:0000/00BD:........:Modules directory (base part)
0102: 0 : Dd : 60121: 1:Yes :Error:Error:0000/000B:........:Heads map module image
0102: 1 : Dd : 60121: 1:Yes :Error:Error:0000/000B:........:Heads map module image
0103: 0 : Dd : 60119: 2:Yes :Error:Error:0000/009A:........:ROM adaptives SA images
0103: 1 : Dd : 60119: 2:Yes :Error:Error:0000/009A:........:ROM adaptives SA images
0104: 0 : Dd : 60118: 1:Yes :Error: Ok : 0000 :........:Microprogram version image
0104: 1 : Dd : 60118: 1:Yes :Error: Ok : 0000 :........:Microprogram version image
0105: 0 : Dd : 60116: 2:Yes :Error:Error:0025/0076:%%%%%%%%:ROM translator SA images
0105: 1 : Dd : 60116: 2:Yes :Error:Error:0025/0076:%%%%%%%%:ROM translator SA images
0107: 0 : Dd : 60115: 1:Yes :Error:Error:0000/0022:........:ROM module image
0107: 1 : Dd : 60115: 1:Yes :Error:Error:0000/0022:........:ROM module image
0002: 0 : B : 60163: 2:Yes :Error:Error:0051/0038:....Yq_.:Configuration (HDD ID)
0002: 1 : B : 60163: 2:Yes :Error:Error:0051/0038:....Yq_.:Configuration (HDD ID)
0017: 0 : B : 60165: 62:Yes :Error:Error:0000/00CC:.%@...(.:Loaded part of microprogram code
0017: 1 : B : 60165: 62:Yes :Error:Error:0000/00CC:.%@...(.:Loaded part of microprogram code
001B: 0 : B : 60227: 113:Yes :Error:Error:0000/0023:........:Loaded part of microprogram code
001B: 1 : B : 60227: 113:Yes :Error:Error:0000/0023:........:Loaded part of microprogram code
000C: 0 : B : 1383: 4:Yes : Ok :Error:004C/00F8:00010100:Models table
000C: 1 : B : 1383: 4:Yes : Ok :Error:004C/00F8:00010100:Models table
0034: 0 : C : 1387: 12:Yes :Error: Ok : 0000 :........:G-List (Grown defect list)
0034: 1 : C : 1387: 12:Yes :Error: Ok : 0000 :........:G-List (Grown defect list)
0032: 0 : Ad : 1399: 32:Yes :Error:Error:0000/0035:........:Relo Bad Block Module
0032: 1 : Ad : 1399: 32:Yes :Error:Error:0000/0035:........:Relo Bad Block Module
0036: 0 : Ad : 1431: 11:Yes : Ok : Ok : 004C :00010000:T-List Module
0036: 1 : Ad : 1431: 11:Yes : Ok : Ok : 004C :00010000:T-List Module
0029: 0 : B : 1442: 5:Yes : Ok : Ok : 004C :00010000:Loaded part of microprogram code
0029: 1 : B : 1442: 5:Yes : Ok : Ok : 004C :00010000:Loaded part of microprogram code
0040: 0 : As : 1447: 57:Yes : Ok : Ok : 004C :00010000:Adaptive data
0040: 1 : As : 1447: 57:Yes : Ok : Ok : 004C :00010000:Adaptive data
0041: 0 : As : 1504: 57:Yes : Ok : Ok : 004C :00010000:Adaptive data
0041: 1 : As : 1504: 57:Yes : Ok : Ok : 004C :00010000:Adaptive data
0042: 0 : As : 1561: 57:Yes : Ok : Ok : 004C :00010000:Adaptive data
0042: 1 : As : 1561: 57:Yes : Ok : Ok : 004C :00010000:Adaptive data
0043: 0 : As : 1618: 57:Yes : Ok : Ok : 004C :00010000:Adaptive data
0043: 1 : As : 1618: 57:Yes : Ok : Ok : 004C :00010000:Adaptive data
004E: 0 : B : 1675: 48:Yes : Ok : Ok : 004C :00210020:Loaded part of microprogram code
004E: 1 : B : 1675: 48:Yes : Ok : Ok : 004C :00210020:Loaded part of microprogram code
0049: 0 : As : 1723: 3:Yes : Ok : Ok : 004C :00010000:Adaptive data
0049: 1 : As : 1723: 3:Yes : Ok : Ok : 004C :00010000:Adaptive data
004A: 0 : As : 1726: 9:Yes : Ok : Ok : 004C :00010000:Adaptive data
004A: 1 : As : 1726: 9:Yes : Ok : Ok : 004C :00010000:Adaptive data
004D: 0 : As : 1735: 1:Yes : Ok : Ok : 004C :00010000:Adaptive data
004D: 1 : As : 1735: 1:Yes : Ok : Ok : 004C :00010000:Adaptive data
0003: 0 : As : 1736: 27:Yes : Ok : Ok : 004C :00020000:Format Select Data Module
0003: 1 : As : 1736: 27:Yes : Ok : Ok : 004C :00020000:Format Select Data Module
0004: 0 : B : 1763: 981:Yes : Ok : Ok : 004C :00020000:Family models configuration (Main)
0004: 1 : B : 1763: 981:Yes : Ok : Ok : 004C :00020000:Family models configuration (Main)
0025: 0 : : 2744: 257:Yes : Ok : Ok : 004C :00210020:
0025: 1 : : 2744: 257:Yes : Ok : Ok : 004C :00210020:
0026: 0 : : 3001: 129:Yes : Ok : Ok : 004C :00210020:
0026: 1 : : 3001: 129:Yes : Ok : Ok : 004C :00210020:
0038: 0 : B : 3130: 257:Yes : Ok : Ok : 004C :00210020:Loaded part of microprogram code
0038: 1 : B : 3130: 257:Yes : Ok : Ok : 004C :00210020:Loaded part of microprogram code
0039: 0 : B : 3387: 17:Yes : Ok : Ok : 004C :00210020:Loaded part of microprogram code
0039: 1 : B : 3387: 17:Yes : Ok : Ok : 004C :00210020:Loaded part of microprogram code
0037: 0 : Dr : 3404: 1:Yes : Ok : Ok : 004C :00010000:Gain Call Data Module
0037: 1 : Dr : 3404: 1:Yes : Ok : Ok : 004C :00010000:Gain Call Data Module
002D: 0 : Dr : 3405: 300:Yes : Ok :Error:004C/00D0:00210020:Debug Log
002D: 1 : Dr : 3405: 300:Yes : Ok :Error:004C/00D0:00210020:Debug Log
002E: 0 : B : 3705: 300:Yes :Error:Error:0000/00AB:........:Loaded part of microprogram code
002E: 1 : B : 3705: 300:Yes :Error:Error:0000/00AB:........:Loaded part of microprogram code
0021: 0 : B : 4005: 70:Yes : Ok : Ok : 004C :00810003:S.M.A.R.T.
0021: 1 : B : 4005: 70:Yes : Ok : Ok : 004C :00810003:S.M.A.R.T.
0022: 0 : B : 4075: 70:Yes : Ok : Ok : 004C :00810003:S.M.A.R.T.
0022: 1 : B : 4075: 70:Yes : Ok : Ok : 004C :00810003:S.M.A.R.T.
0023: 0 : B : 4145: 70:Yes : Ok : Ok : 004C :00810003:S.M.A.R.T. Log (reserved)
0023: 1 : B : 4145: 70:Yes : Ok : Ok : 004C :00810003:S.M.A.R.T. Log (reserved)
0024: 0 : B : 4215: 70:Yes : Ok : Ok : 004C :00810003:S.M.A.R.T. Log (reserved)
0024: 1 : B : 4215: 70:Yes : Ok : Ok : 004C :00810003:S.M.A.R.T. Log (reserved)
0068: 0 : : 4285: 70:Yes : Ok : Ok : 004C :00810003:
0068: 1 : : 4285: 70:Yes : Ok : Ok : 004C :00810003:
0069: 0 : : 4355: 70:Yes : Ok : Ok : 004C :00810003:
0069: 1 : : 4355: 70:Yes : Ok : Ok : 004C :00810003:
006A: 0 : : 4425: 70:Yes : Ok : Ok : 004C :00810003:
006A: 1 : : 4425: 70:Yes : Ok : Ok : 004C :00810003:
00B5: 0 : Dr : 4495: 160:Yes : Ok : Ok : 004C :00210020:WRRO Log Module
00B5: 1 : Dr : 4495: 160:Yes : Ok : Ok : 004C :00210020:WRRO Log Module
006B: 0 : B : 4655: 4:Yes : Ok : Ok : 004C :00210020:Loaded part of microprogram code
006B: 1 : B : 4655: 4:Yes : Ok : Ok : 004C :00210020:Loaded part of microprogram code
003A: 0 : : 4659: 3:Yes : Ok : Ok : 004C :00000100:
003A: 1 : : 4659: 3:Yes : Ok : Ok : 004C :00000100:
0028: 0 : Dr : 4662: 16:Yes : Ok : Ok : 004C :00030000:Factory Self Test script
0028: 1 : Dr : 4662: 16:Yes : Ok : Ok : 004C :00030000:Factory Self Test script
003B: 0 : : 4678: 16:Yes : Ok : Ok : 004C :00030000:
003B: 1 : : 4678: 16:Yes : Ok : Ok : 004C :00030000:
003C: 0 : : 4694: 16:Yes : Ok : Ok : 004C :00030000:
003C: 1 : : 4694: 16:Yes : Ok : Ok : 004C :00030000:
003D: 0 : : 4710: 16:Yes : Ok : Ok : 004C :00030000:
003D: 1 : : 4710: 16:Yes : Ok : Ok : 004C :00030000:
003E: 0 : : 4726: 16:Yes : Ok : Ok : 004C :00030000:
003E: 1 : : 4726: 16:Yes : Ok : Ok : 004C :00030000:
003F: 0 : : 4742: 16:Yes : Ok : Ok : 004C :00030000:
003F: 1 : : 4742: 16:Yes : Ok : Ok : 004C :00030000:
006F: 0 : B : 4759: 77:Yes : Ok : Ok : 004C :00210020:Loaded part of microprogram code
006F: 1 : B : 4759: 77:Yes : Ok : Ok : 004C :00210020:Loaded part of microprogram code
00DE: 0 : Dr : 57596: 110:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00DE: 1 : Dr : 57596: 110:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00B6: 0 : Dr : 57706: 100:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00B6: 1 : Dr : 57706: 100:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00D5: 0 : Dr : 57806: 126:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00D5: 1 : Dr : 57806: 126:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00DA: 0 : Dr : 57932: 121:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00DA: 1 : Dr : 57932: 121:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00DB: 0 : Dr : 58053: 103:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00DB: 1 : Dr : 58053: 103:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00DF: 0 : Dr : 58156: 131:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00DF: 1 : Dr : 58156: 131:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00DD: 0 : Dr : 58287: 95:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00DD: 1 : Dr : 58287: 95:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00D6: 0 : Dr : 58382: 99:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00D6: 1 : Dr : 58382: 99:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
3402: 0 : : 58481: 100:Yes : Ok : Ok : 004C :V344....:
3402: 1 : : 58481: 100:Yes : Ok : Ok : 004C :V344....:
00D7: 0 : Dr : 58581: 100:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00D7: 1 : Dr : 58581: 100:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00D2: 0 : Dr : 58681: 90:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00D2: 1 : Dr : 58681: 90:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00BB: 0 : Dr : 58771: 100:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00BB: 1 : Dr : 58771: 100:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00D9: 0 : Dr : 58871: 84:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00D9: 1 : Dr : 58871: 84:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00D4: 0 : Dr : 58955: 88:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00D4: 1 : Dr : 58955: 88:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00DC: 0 : Dr : 59043: 78:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00DC: 1 : Dr : 59043: 78:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00D0: 0 : Dr : 59121: 77:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00D0: 1 : Dr : 59121: 77:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00D3: 0 : Dr : 59198: 76:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00D3: 1 : Dr : 59198: 76:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00F7: 0 : : 59274: 96:Yes : Ok : Ok : 004C :V344....:
00F7: 1 : : 59274: 96:Yes : Ok : Ok : 004C :V344....:
00BA: 0 : Dr : 59370: 100:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00BA: 1 : Dr : 59370: 100:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00B9: 0 : Dr : 59470: 100:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00B9: 1 : Dr : 59470: 100:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00BC: 0 : Dr : 59570: 99:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00BC: 1 : Dr : 59570: 99:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00D8: 0 : Dr : 59669: 86:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00D8: 1 : Dr : 59669: 86:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00BD: 0 : : 59755: 126:Yes : Ok : Ok : 004C :V344....:
00BD: 1 : : 59755: 126:Yes : Ok : Ok : 004C :V344....:
00BE: 0 : Dr : 59881: 27:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00BE: 1 : Dr : 59881: 27:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
3400: 0 : : 59908: 101:Yes : Ok : Ok : 004C :V344....:
3400: 1 : : 59908: 101:Yes : Ok : Ok : 004C :V344....:
00B8: 0 : Dr : 60009: 2:Yes : Ok : Ok : 004C :V344....:Single Plug Test Communication Module
00B8: 1 : Dr : 60009: 2:Yes : Ok : Ok : 004C :V344....:Single Plug Test Communication Module
00BF: 0 : Dr : 60011: 8:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00BF: 1 : Dr : 60011: 8:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00E0: 0 : Dr : 55591:2000:Yes : Ok : Ok : 004C :V344....:Factory Self Test defects log
00E0: 1 : Dr : 55591:2000:Yes : Ok : Ok : 004C :V344....:Factory Self Test defects log
00E1: 0 : Dr : 53591:2000:Yes : Ok : Ok : 004C :V344....:Factory Self Test defects log
00E1: 1 : Dr : 53591:2000:Yes : Ok : Ok : 004C :V344....:Factory Self Test defects log
00E2: 0 : Dr : 51591:2000:Yes : Ok : Ok : 004C :V344....:Factory Self Test defects log
00E2: 1 : Dr : 51591:2000:Yes : Ok : Ok : 004C :V344....:Factory Self Test defects log
00E3: 0 : Dr : 49591:2000:Yes : Ok : Ok : 004C :V344....:Factory Self Test defects log
00E3: 1 : Dr : 49591:2000:Yes : Ok : Ok : 004C :V344....:Factory Self Test defects log
00E8: 0 : Dr : 48957: 634:Yes : Ok : Ok : 004C :V344....:Factory Self Test head 0 defects log
00E8: 1 : Dr : 48957: 634:Yes : Ok : Ok : 004C :V344....:Factory Self Test head 0 defects log
00E9: 0 : Dr : 48323: 634:Yes : Ok : Ok : 004C :V344....:Factory Self Test head 1 defects log
00E9: 1 : Dr : 48323: 634:Yes : Ok : Ok : 004C :V344....:Factory Self Test head 1 defects log
00EA: 0 : Dr : 47689: 634:Yes : Ok : Ok : 004C :V344....:Factory Self Test head 2 defects log
00EA: 1 : Dr : 47689: 634:Yes : Ok : Ok : 004C :V344....:Factory Self Test head 2 defects log
00EB: 0 : Dr : 47055: 634:Yes : Ok : Ok : 004C :V344....:Factory Self Test head 3 defects log
00EB: 1 : Dr : 47055: 634:Yes : Ok : Ok : 004C :V344....:Factory Self Test head 3 defects log
00E6: 0 : Dr : 60019: 64:Yes : Ok : Ok : 004C :V344....:Factory Self Test log
00E6: 1 : Dr : 60019: 64:Yes : Ok : Ok : 004C :V344....:Factory Self Test log
00E7: 0 : Dr : 60083: 32:Yes : Ok :Error:004C/0076:V344....:Factory Self Test parameters module
00E7: 1 : Dr : 60083: 32:Yes : Ok :Error:004C/0076:V344....:Factory Self Test parameters module
00B7: 0 : Dr : 61348: 16:Yes : Ok : Ok : 004C :NOT_INIT:Test Clamp Data
00B7: 1 : Dr : 61348: 16:Yes : Ok : Ok : 004C :NOT_INIT:Test Clamp Data
00FA: 0 : Dr : 61092: 256:Yes : Ok : Ok : 004C :NOT_INIT:Butterfly Log
00FA: 1 : Dr : 61092: 256:Yes : Ok : Ok : 004C :NOT_INIT:Butterfly Log
00FB: 0 : Dr : 46455: 600:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00FB: 1 : Dr : 46455: 600:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00FC: 0 : Dr : 61088: 4:Yes : Ok : Ok : 004C :NOT_INIT:Factory Self Test module
00FC: 1 : Dr : 61088: 4:Yes : Ok : Ok : 004C :NOT_INIT:Factory Self Test module
00FD: 0 : Dr : 45943: 512:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00FD: 1 : Dr : 45943: 512:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00FE: 0 : Dr : 44343:1600:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00FE: 1 : Dr : 44343:1600:Yes : Ok : Ok : 004C :V344....:Factory Self Test module
00EE: 0 : Dr : 61083: 5:Yes : Ok : Ok : 004C :NOT_INIT:RRO Data Log
00EE: 1 : Dr : 61083: 5:Yes : Ok : Ok : 004C :NOT_INIT:RRO Data Log
3E00: 0 : : 61078: 5:Yes : Ok : Ok : 004C :V344....:
3E00: 1 : : 61078: 5:Yes : Ok : Ok : 004C :V344....:
00C4: 0 : Dr : 43960: 161:Yes : Ok : Ok : 004C :BE.44 :Calibrations module
00C4: 1 : Dr : 43960: 161:Yes : Ok : Ok : 004C :BE.44 :Calibrations module
00A2: 0 : : 44121: 56:Yes : Ok : Ok : 004C :BE.44 :
00A2: 1 : : 44121: 56:Yes : Ok : Ok : 004C :BE.44 :
00C5: 0 : Dr : 44177: 94:Yes : Ok : Ok : 004C :BE.25...:Calibration script (DCM)
00C5: 1 : Dr : 44177: 94:Yes : Ok : Ok : 004C :BE.25...:Calibration script (DCM)
00C3: 0 : : 5153: 116:Yes : Ok : Ok : 004C :BE.44 :
00C3: 1 : : 5153: 116:Yes : Ok : Ok : 004C :BE.44 :
00C8: 0 : : 5269: 117:Yes : Ok : Ok : 004C :BE.44 :
00C8: 1 : : 5269: 117:Yes : Ok : Ok : 004C :BE.44 :
0091: 0 : Dr : 5386: 4:Yes : Ok : Ok : 004C :BE.44 :Calibrations module
0091: 1 : Dr : 5386: 4:Yes : Ok : Ok : 004C :BE.44 :Calibrations module
00CC: 0 : Dr : 60146: 6:Yes :Error: Ok : 0000 :........:Calibrations module
00CC: 1 : Dr : 60146: 6:Yes :Error: Ok : 0000 :........:Calibrations module
00CA: 0 : Dr : 60979: 6:Yes : Ok : Ok : 004C :NOT_INIT:Calibrations module
00CA: 1 : Dr : 60979: 6:Yes : Ok : Ok : 004C :NOT_INIT:Calibrations module
0099: 0 : : 5488: 12:Yes : Ok : Ok : 004C :NOT_INIT:
0099: 1 : : 5488: 12:Yes : Ok : Ok : 004C :NOT_INIT:
0098: 0 : : 60985: 24:Yes : Ok : Ok : 004C :NOT_INIT:
0098: 1 : : 60985: 24:Yes : Ok : Ok : 004C :NOT_INIT:
00CB: 0 : Dr : 5500: 12:Yes : Ok : Ok : 004C :NOT_INIT:Calibrations module
00CB: 1 : Dr : 5500: 12:Yes : Ok : Ok : 004C :NOT_INIT:Calibrations module
00CD: 0 : Dr : 61009: 12:Yes : Ok : Ok : 004C :NOT_INIT:Calibrations module
00CD: 1 : Dr : 61009: 12:Yes : Ok : Ok : 004C :NOT_INIT:Calibrations module
00CF: 0 : Dr : 5512: 12:Yes : Ok : Ok : 004C :NOT_INIT:Calibrations module
00CF: 1 : Dr : 5512: 12:Yes : Ok : Ok : 004C :NOT_INIT:Calibrations module
00CE: 0 : Dr : 61021: 12:Yes : Ok : Ok : 004C :NOT_INIT:Calibrations module
00CE: 1 : Dr : 61021: 12:Yes : Ok : Ok : 004C :NOT_INIT:Calibrations module
0093: 0 : Dr : 5524: 12:Yes : Ok : Ok : 004C :NOT_INIT:Calibrations module
0093: 1 : Dr : 5524: 12:Yes : Ok : Ok : 004C :NOT_INIT:Calibrations module
00C1: 0 : Dr : 25: 1:Yes : Ok : Ok : 004C :NOT_INIT:Calibrations module
00C1: 1 : Dr : 25: 1:Yes : Ok : Ok : 004C :NOT_INIT:Calibrations module
00C2: 0 : Dr : 5390: 2:Yes : Ok : Ok : 004C :BE.44 :Calibrations module
00C2: 1 : Dr : 5390: 2:Yes : Ok : Ok : 004C :BE.44 :Calibrations module
00C7: 0 : Dr : 57591: 1:Yes : Ok : Ok : 004C :NOT_INIT:Calibrations module
00C7: 1 : Dr : 57591: 1:Yes : Ok : Ok : 004C :NOT_INIT:Calibrations module
009E: 0 : Dr : 60152: 3:Yes :Error: Ok : 0000 :........:Calibrations module
009E: 1 : Dr : 60152: 3:Yes :Error: Ok : 0000 :........:Calibrations module
MODULES DIRECTORY (01)
Location State
0 ABA:0 Size:24 Ok
1 ABA:0 Size:24 Ok
Modules number.......................... : 325
CONFIGURATION MODULE (02)
Log DCM (C5)
Location State
0 ABA:44177 Size:94 Ok
1 ABA:44177 Size:94 Ok
TORTORNADO TOR
+--- Head DCM Codes -------- Media DCM Codes -----+
| ALPS: A,B | SHOWA: F,K,Q,7 |
| SAE: D | TRACE: D,E,J,M,P,3,4,9 |
| SAEH : E | EXP/TA5: L,N,R |
| SAET : F | |
| WDBTIOMAN : 8 | |
P-List (33)
Location State
0 ABA:427 Size:563 Ok
1 ABA:427 Size:563 Ok
Defects number.......................... : 1713
G-List (34)
Location State
0 ABA:1387 Size:12 Header
1 ABA:1387 Size:12 Header
Cheers,
Chris Lees
WD3200AAJS-40RYA0 shows wrong size.
- RescueDRL@gmail.com
Re: WD3200AAJS-40RYA0 shows wrong size.
From what I understood, you used a donor PCB.
First of all, can you read ROM from patient PCB in safe mode?
Is so, copy ROM and ROM modules into donor PCB and try again.
Hi, thanks for the info. I backed up the Patient, and then opened
the Donor in Kernel mode. I wrote ROM and Modules to the Donor
card, powered off, swapped cards, and now the Patient reads
Exactly like before, only 14.93GB's, wrong size, Anything I missed?
Sorry, I should have said: I reversed the procedure and rebuilt the Donor
working, so I know my procedure was correct.
Chris
Chris
Hi again,
You got a few damaged modules.
Can you make a resume of what modules can't be read?
Besides that, can you read tracks?
You can try to read the damaged modules in composite, though I am not so sure this is possible with both copies bad. Maybe tracks can be read?
You have problems with G-List, Relcoated Bad Blocks Module, both can be replaced with mods from donor and translator can be regenerated after. HDD ID can also be replaced from same model donor. Some other modules, such as modules related to 'microprogram code' are all related to overlays and if you cannot repair you should write from donor of matching model and firmware, in your case '00210020'.
Alternatively, if you do have access to a donor you may try HotSwap process, this should be a little easier and will not involve writing to and replacing the SA. If you are unsure about what is safe to write to SA then HotSwap will be a better option for you
From the tracks you could check if you have all necessary modules, and if you have a donor, then you could do smart hot swap, as it would be much easier than trying to fix all of them in the patient drive.
