module #11 for WD10EADS-00M2B0 and WD1602ABKS-18N8A0
mee
Postby mee » 10.07.10, 11:14
Hi everyone,
Someone have the module #11 of
WD10EADS-00M2B0 (Rom ver. :0010002G) and
WD1602ABKS-18N8A0(Rom ver. :0005008V)
The Hdd has this error,
Module : 11............................. : Module ID 11 reading error Data request error - Device Error Detected: "FM ERR CHECKSUM"
I need it very much ,Please help me.
Thank you,
mee.
Re: module #11 for WD10EADS-00M2B0 and WD1602ABKS-18N8A0
Postby AJ2008 » 13.07.10, 07:27
Can you access SA via ID in utility? It may be possible to read your module by ID option, and error suggests checksum could be bad which you can repair in the Hex Editor installed alongside your UDMA.
mee
Postby mee » 19.07.10, 13:19
Hi AJ2008,
Thank you for your reply and sorry for delay.
I had try with module 11 already but cannot read by ID option ,an error below
Reading modules
Into folder............................. : <HDD Profile>\Data\Modules\
Module : 11............................. : Module ID 11 reading error Data request error - Device Error Detected: "DISK ECU UNSAFE ERROR"
So, if you have anyway for help please let me know,, (advise)
Thank you in advance,
mee.
