To All who can help:
I need a Loader for WD5000AAKS - 22A7B2 urgently.
below are results from log:
Techno mode key
ROM:
ROM version............................. : 05.DGE
ROM generation.......................... : 05.DGE
Link table version...................... : 04.AL.
Heads number............................ : 3
Heads number in use..................... : 3
Head map................................ : 0,1,2
ROM Firmware version.................... : 000500DG
Need Loader for WD5000AAKS - 22A7B2
Re: Need Loader for WD5000AAKS - 22A7B2
This log is made from disk in Kernel mode. Can you access SA? Does spindle stop?
If disk powers down it is likely the fault is with physical components, heads maybe. If power is constant, possible may be SA damage.
If spindle stops, then LDR is of no use im afraid.
Thanks for the response.
The disk however does not power down therefore i am thinking LDR will help me.
Please anyone.
Please anyone.
SO no one can help me? It has been quite a while and this is a very important case. Sigh.
I have something here that might be of any help.
Here it is:
http://rapidshare.com/files/423023271/W ... 663590.rar
Here it is:
Are you still looking.
I have WD5000AAKS - 22A7B0 01.03B01
Does that help? If so PM me your email.
