Hi to all,
i would like to know if is possible in DE to make a raw recovery by header information
I can see the files Header Information in Hex Decimal,
Example
JPEG Images
ff d8
but i dont find any place in DE where i can put or build my own file type.
i would like to know how other users make this.
Jose
RAW RECOVERY by Header Information
Re: RAW RECOVERY by Header Information
Can't you click on the "Raw Recovery Reference Book" button under the raw recovery mode? It gives a grep menu and you can add your signatures?
Hi to all!
Open a good edithexa remove copy grep to add the raw Recovery Reference Book in DE.
I hope I have contributed...
nothing is impossible!
sempre wrote:Hi to all!
The Grep and the file header from a hex editor are not the same. they are structured differently, GREP (I think) seperates bytes with a '/' while a Hex Editor does not so copying the information exactly will not work.
I think tech support at Acelab should be able to clarify this one.
hi, sorry,
In winhex is function menu edit =>copy block=> GREP HEX
Is correct?
Please opnions...
Thanks!!
Is correct?
Please opnions...
Thanks!!
