Data Extractor HANGS
ZeBong
Postby ZeBong » 23.12.09, 15:43
Data Extractor hang when using the "read commad" , do not use hardware retries.
I Have cases when i try to read with this option the DE star reading ok, " green" but if the disk have a problem or i need to STOP the reading, DE still HANG and i can not do nothing i have to kill the JOB in task manager.
Anyone had seen this in DE.
ZeBong
Re: Data Extractor HANGS
Postby AJ2008 » 24.12.09, 13:34
I have seen similar case with SATA drives when using alternative SATA adaptors, now I try use only PC {ATA-SATA adaptors from ACE.
Is problem the same with 'use hardware retries' option?
I have seen similar case with SATA drives when using alternative SATA adaptors, now I try use only PC PATA-SATA adaptors from ACE.
Return to “Data Extractor”
Users browsing this forum: No registered users and 22 guests
