WD10EAVS-32D7B1 (KERMIT)
swersig
Postby swersig » 11.12.09, 11:58
ROM:
ROM version............................. : 05.BME
ROM generation.......................... : 05.BME
Link table version...................... : 04.3D.
Head map................................ : 2,3,4,5,6,7
Firmware version........................ : 000500BM
Additional info from label:
DATE: 19 FEB 2009
DCM DANNNT2MFB
Anyone got modules/loader for this drive ?
thanks
Re: WD10EAVS-32D7B1 (KERMIT)
Postby AJ2008 » 11.12.09, 12:51
I have some Kermit resources, but nothing matching the firmware you need sorry.
what is the problem with your Kermit?
swersig
Postby swersig » 11.12.09, 13:52
on power on it stays busy. sa seems to have no defects, i can read all cyls (-1 to -170), all heads (2 - 7, HM is 234567). i suspect bad pcb or logical damage to sa. the latter i cant sort out since i dont have any resources on these drives. this drive sounds normal on power up and wasnt dropped/didnt have power surge. cylinders on head 2 and 3 (main/backup sa i think) are identical. any ideas?
thanks
dmarques
Postby dmarques » 12.01.10, 13:53
Do you still need this resources?
David
swersig
Postby swersig » 12.01.10, 16:12
no, thank you.
i managed to read sa tracks and wrote tool to extract the modules. then i did a hot swap and got the data.
thanks for asking,
swersig
Postby AJ2008 » 13.01.10, 23:02
Thats good news. I suspect you had a weak head preventing correct translator initilisation, this has been talked about in different topics.
