ST3160815A App Code
rcz
ST3160815A App Code
Postby rcz » 19.11.09, 09:08
Hi to all,
I've got a Seagate ST3160815A 7200.10 which stays in BSY and terminal shows "ERR 06 : APP CODE".
According to the customer, nothing has been done, but I really have a doubt as the label has been taken off...
So when I try to swap the board (the whole board), the HDD stays in BSY and DSC and terminal shows a Er=43.
A can read all parts of the SA without error but only App Code have data inside...
I tried to swap heads with good ones, but it's the same.
If you have an idea, please tell me :) !
ZeBong
Re: ST3160815A App Code
Postby ZeBong » 19.11.09, 23:53
this looks like add to pending error.
Use the utility in seagate to make that.
Good luck.
rcz
Postby rcz » 20.11.09, 09:49
Sorry I did a mistake, it gives me Er 33 and 00... I've got 2 Seagate and it's a litlle bit confused.
Here is the log with his board (wondering if it's really native ?) :
Reset
4096k x 16 DRAM
NHAWK - 1_Disk S-41 10-23-06_16:40
HM SFI
ERR A6: App Code
F>
Here is the log, with boards of different donors :
Reset
1024k x 16 DRAM
NHAWK - 1_Disk S-42 03-27-07_13:01
Buzz HM SFI
(P)PATA Reset
Failed sys sect. write! Nwt Er 33 RdWr 13af0.00.0003
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
Failed sys sect. write! Nwt Er 00 RdWr 13af0.00.0003
Nothing happens after that, the drive stays in BSY and DSC, even after half an hour.
steven
Postby steven » 21.11.09, 04:09
use the method like zebong tell you.
run utility setup from DE which have link with Seagate utility.
u need loader file
Postby AJ2008 » 23.11.09, 10:19
You need use a LDR as mentioned to begin a DE task, select 'Utility Actions' and check the appropriate options. From the last terminal log you should be able to reach 'T>', if this is possible you can create a LDR from your patient drive.
rcz
Postby rcz » 24.11.09, 10:54
Thanks for reply.
I wasn't able to initialize the disk with the loader. Maybe I didn't used the correct option...
Whatever the customer decided his data wasn't so important.
Thanks again for your help.
