Rewrite partition table
zeroalpha
Postby zeroalpha » 19.10.09, 03:35
If I perform a quick disk analysis with DE it finds the users partitions that have been lost with data intact. Can I rewrite those partitions back to the hard drive using DE?
steven
Re: Rewrite partition table
Postby steven » 20.10.09, 03:42
yes U can. do it from virtual partition or you can edit it manually directly to MBR
zeroalpha
Postby zeroalpha » 21.10.09, 04:37
Thanks steven, I assume you mean "save virtual boot". If so that didn't work and I had to do it manually.
admin
Postby admin » 02.11.09, 12:46
zeroalpha wrote:Thanks steven, I assume you mean "save virtual boot". If so that didn't work and I had to do it manually.
:idea:
No need to modify MBR sector if you gonna just to save a user data.
Open sector edit. Find a sector with boot(s) then select from menu View as...-->NTFS(FAT) boot, Service-->add virtual boot.
Return to “Data Extractor”
