SA structure test result. how to repair this disk; HELP ....
djmd60
Postby djmd60 » 03.08.09, 19:25
This disk is the maxtor romulus dsp; firmware daho17ko; build year 2001
the sa structure test result is:
SA structure test
Error ..................................... Techno receive error unexpected error: Receive DIAG command error
Checking UList
Error ..................................... Module 37 reading error. unexpected error: UBA 0 (1) reading error. unexpected error: Techno receive error unexpected error: Receive DIAG command error
HDD configuration module
Error ..................................... Module 1F reading error. unexpected error: UBA 4 (1) reading error. unexpected error: Techno receive error unexpected error: Receive DIAG command error
Checking Calibration adaptives
Error ..................................... Module 1E reading error. unexpected error: UBA 365 (1) reading error. unexpected error: Techno receive error unexpected error: Receive DIAG command error
Checking User data adaptives
Error ..................................... Module 21 reading error. unexpected error: UBA 325 (3) reading error. unexpected error: Techno receive error unexpected error: Receive DIAG command error
Checking Zone Table
Read ...................................... Yes
# : Start Cyl: End Cyl: SPT
1 : 611: 4212: 896
2 : 4213: 7814: 871
3 : 7815: 11416: 851
4 : 11417: 15018: 821
5 : 15019: 18620: 806
6 : 18621: 22222: 784
7 : 22223: 25824: 756
8 : 25825: 29426: 728
9 : 29427: 33028: 696
10 : 33029: 36630: 672
11 : 36631: 40232: 640
12 : 40233: 43834: 610
13 : 43835: 47436: 572
14 : 47437: 51037: 532
15 : 51038: 54638: 497
16 : 54639: 58189: 448
17 : 58195: 58244: 336
Checking DMCS
Error ..................................... Module 1D reading error. unexpected error: UBA 481 (2) reading error. unexpected error: Techno receive error unexpected error: Receive DIAG command error
Checking ROM Copy
Error ..................................... Module 39 reading error. unexpected error: UBA 1304 (3) reading error. unexpected error: Techno receive error unexpected error: Receive DIAG command error
Checking ATA overlays
Checking Techno mode overlays
Checking RZTbl
Error ..................................... Module 78 reading error. unexpected error: UBA 5 (3) reading error. unexpected error: Techno receive error unexpected error: Receive DIAG command error
Checking P-List
Error ..................................... Module 18 reading error. unexpected error: UBA 12 (3) reading error. unexpected error: Techno receive error unexpected error: Receive DIAG command error
Checking G-List
Error ..................................... Module 1B reading error. unexpected error: UBA 483 (3) reading error. unexpected error: Techno receive error unexpected error: Receive DIAG command error
Checking RZTbl-PList
Error ..................................... RZ_Tbl reading error. unexpected error: UBA 5 (3) reading error. unexpected error: Techno receive error unexpected error: Receive DIAG command error
Checking HLists
Checking security
Error ..................................... Module 1A reading error. unexpected error: UBA 368 (1) reading error. unexpected error: Techno receive error unexpected error: Receive DIAG command error
Checking S.M.A.R.T.
[SMRT_T] .................................. Error
[SMRT_A] .................................. Error
[SMRT_AC] ................................. Error
[SMART_SUMMAR] ............................ Error
[SMART_ST] ................................ Error
[SMART_HOSTV] ............................. Error
Checking FMTI
Error ..................................... Module 93 reading error. unexpected error: UBA 698 (3) reading error. unexpected error: Techno receive error unexpected error: Receive DIAG command error
UBA : ID : Size : Module : Importance : Read : Header : CS
0 : 37 : 1 : U_LIST : Ad : No : :
4 : 1F : 1 : DISK : B : No : :
5 : 78 : 7 : RZTBL : Ad : No : :
12 : 18 : 313 : AT_PDL : Ad : No : :
325 : 21 : 10 : RCTF : As : No : :
365 : 1E : 1 : SRV : As : No : :
368 : 1A : 1 : SECU : C : No : :
369 : 2F : 1 : [SMRT_T] : C : No : :
370 : 30 : 1 : [SMRT_A] : C : No : :
371 : 63 : 1 : [SMRT_AC] : C : No : :
386 : 22 : 1 : ATAF : B : No : :
390 : 34 : 90 : ARREH : Dr : No : :
480 : 48 : 1 : [LABEL] : Dr : No : :
481 : 1D : 2 : DMCS : C : No : :
483 : 1B : 10 : AT_POL : C : No : :
496 : 64 : 1 : MAXATG : B : No : :
520 : 5E : 128 : EVTLG : Dr : No : :
698 : 93 : 128 : FMTI : Ad : No : :
648 : 70 : 1 : [SMART_SUMMAR] : Dr : No : :
649 : 71 : 1 : [SMART_ST] : Dr : No : :
650 : 72 : 32 : [SMART_HOSTV] : Dr : No : :
690 : 7B : 8 : FW : Dr : No : :
1 304 : 39 : 256 : [ROM SA] : B : No : :
1 560 : 38 : 160 : [OVL ATA] : B : No : :
1 720 : 4F : 608 : [OVL Tech] : B : No : :
2 488 : 33 : 6004 : [HUTL/HUSR] : Dd : Yes : Error : Error
SUMMARY
HDD modules necessary for start have reading errors. To eliminate them, check the SA surface with option "Correct BAD blocks by writing". Attention. After you do recovery, launch SA checking one more time because some modules can become unavailable for writing.
Modules | Comment
1F | Module with HDD identification is damaged. You can rewrite it from HDD
| of the same module of the same family
1A,2F,30,63,34 | If S.M.A.R.T. modules are damaged HDD starts some longer as usual. It
| does not mater to get access to user data.
22 | Config module is damaged. It is necessary to rewrite it from any HDD
| of the same family to recover it.
37,78,18,1D | Translator modules are defective. For restoration it should be
| performed:
| 1) To perform SA surface checking with the option of restoration BAD
| blocks via writing
| 2) To clear P and G-List
| 3) To restart HDD in normal mode
| 4) To perform translator regeneration
39,38,4F | Microcode modules are damaged. To recover them, you should write ALL
| ones with a code from another HDD of the same family. Attention! If
| you rewrite not all three modules, but only damaged ones, then it is
| probable that software versions won`t coincide and HDD won`t work
| correctly.
21,1E,48,1B,64,5E,70,71,72,7B,33 | HDD has errors not critical for its normal operation. But before
| copying user data you should switch off automatic adding of defects to
| the defect-list.
-BR-
Re: SA structure test result. how to repair this disk; HELP ....
Postby -BR- » 05.08.09, 09:35
All the modules are bad, that is not right
I think that you might have one of the following:
#1) bad pcb
#2) used an incompatible loader for accessing sa
#3) bad head
try to check items #1 and #2 first as they are the most easy to fix
i believe that you can have a good set of loaders by downloading and installing the maxtor updates from your update box
good luck
-BR-
Return to “Maxtor”
