Seagate head compatibility
-BR-
Postby -BR- » 12.06.09, 00:33
Does anyone know for sure what is the correct criteria when selecting a donor for head replacement in Seagate 7.200.X ???
For example (7200.7):
Pcb is ok, tested with one of the donors
Hdd to recover data:
MODEL: ST380011A
S/N: 5JVMTVNZ
P/N: 9W2003-371
HDA P/N: 100316339
CONFIG: D8J-02
FW: 8.01
DATE CODE: 05412
SITE CODE: WU
in red the few differences
between donors and bad hdd
Selected donor1:
MODEL: ST380011A
S/N: 4JV070HP
P/N: 9W2003-371
HDA P/N: 100316764
CONFIG: D8J-02
FW: 8.01
DATE CODE: 05154
SITE CODE: TK
Selected donor2:
MODEL: ST380011A
S/N: 5JVWW18B
P/N: 9W2003-399
HDA P/N: 100348969
CONFIG: CXN-01
FW: 8.01
DATE CODE: 06333
SITE CODE: WU
Selected donor3:
MODEL: ST380011A
S/N: 5JVM28V3
P/N: 9W2003-314
HDA P/N: 100316764
CONFIG: D5C-03
FW: 8.01
DATE CODE: 05396
SITE CODE: WU
But after exchange only head mask in terminal :(
After testings, heads were returned to original donors
All of them returned to work perfectly, all 3 cases!
full lba scan test :shock:
I noticed that in top of a internal plastic piece that hold
terminals to the pcb from the inside, there was 2 writings:
1st = AP2-C
2nd = AG-C
Selected donor1:
1st = AP2-CK
2nd = TI-C
Selected donor2:
1st = AP2-C
2nd = TI-CR
Could it be that the 2nd marking must be AG-C ??
I opened about 8 hdds, the only one with AG-C was the bad one
All the others had TI-XX for 2nd marking and AP2-CX for the 1st
(where X stands for something or even not present)
Any advice is welcome
Thank you
-BR-
Alberto
Re: Seagate head compatibility
Postby Alberto » 12.06.09, 05:49
We use always same model, site code, and fw, works 100% at the most seagate cases, well until 7200.11 but u could use donnor´s with same head, map, and same preamplifier code, are u sure u did correctly the head swap process, means doesnt damaged any MR sensor on the process?, because at that families doesnt need special alignment´s, another cause could be media damaged, did u tried to check by terminal, answer´s before & after head swap?
steven
Postby steven » 12.06.09, 06:17
here is SEAGATE bad DRIVE,
80 GB
CONFIG: D8J-02
FW: 8.01
40 GB
CONFIG: A4K-00
FW: 8.01
this 2 CONFIG is a bad drive.
mostly head will crash and Platter got contaminated specially for A4K series...
ALL your DONOR is compatible with your patient Drive.
-BR-
Postby -BR- » 12.06.09, 22:05
Hi Alberto and Steven,
First of all thank you both :D
I did check terminal before head swap, there was only head mask
I think that it's not our head procediment, since all the donors return to function perfectly and they sufer the exact same procediment
I was starting to think it was some kind of media damage, now steven's reply almost confirmed it
I will now try to clean the original head with isopropilical alchool as a last resource
-BR-
P.S steven are you from ACE?
steven
Postby steven » 14.06.09, 07:50
No. I'm not
Pepe
Postby Pepe » 25.09.09, 19:51
What if u put the patient head into one of the donors?
pepe
Users browsing this forum: Bing [Bot] and 12 guests
