Need Any NVR for HDS721680PLA380
Powermax
Postby Powermax » 20.05.09, 11:20
I need NVR (the version is not imnportant) for HDS721680PLA380
Someone have it please ?
Thank You
Re: Need Any NVR for HDS721680PLA380
Postby ACE_Admin » 28.05.09, 17:01
Very probably you could recover the NV-Ram from SA. Please try to use donor's board and launch "Nv-ram adjustment" command with default values.
See my screenshot attached.
steven
Postby steven » 29.05.09, 12:26
Do u sure your PCB is not the original PCB..
if not try to restore NVR from SA Copy. there is the only option.
if you found other NVR. i dont think it will help u..
I have some of this NVR if you want i can send to you
Powermax
Postby Powermax » 29.05.09, 12:34
No tanks. i solved problem to read NVR from SA. Thank you the same. Bye :)
