Saving LDR from seagate
manel
Postby manel » 13.02.09, 13:19
Seagate: ST3300622AS P/N: 9BD144-303 FIRM: 3.AAE Site Code: WU
When Trying to SAVE LDR it's getting an error and stop savings. Perhaps the question I'm going to do it's to kill myself by ignorant :lol: , but I should do...
It's possible to Save LDR from other disk identical and load on memory with data extractor to access data? PC3000 detects firmware and other values but not the family also the capacity etc. I could paste the log from Saving LDR.
Perhaps I could by-pass the error telling the PC3000 not to save this part? It's necessary to work with data Extractor?
Test : Saving LDR from HDD
HDD profile file......... : C:\Archivos de programa\ACE Lab\PC-3000\Bin\!Profiles\SeagateBara\Barracuda 7200.9 Tonka2\test\Data\LDR\SgLDR.ldr
Will be stored........... : ROM, App, CERT code, CERT tables, Ovl 0, Ovl 1, Stuff, DRV cfg
DRV cfg reading...
DRV cfg reading......................... : Ok
STUFF reading...
Detecting Stuff position...
Terminal : detecting SA bounds...
SA bounds identified
Stuff cylinder.......................... : 0x16350
Vendor Data start....................... : 0x14
PN...................................... : 100399653
STUFF reading........................... : Ok
CERT code reading...
Trying to load CERT
CERT Rev................................ : .08H
CERT code cyl. index.................... : 0x32
CERT code length........................ : 0x408
Block 0, 0x16348 : 0x0 : 0x0 (0x280)
Detecting next track.................... : Ok
Block 1, 0x16348 : 0x1 : 0x0 (0x188)
CERT code reading....................... : Ok
CERT tables reading...
Detecting CERT tables position...
Detecting CERT tables position.......... : 0x1634A : 0x0 : 0x188 (0x18)
CERT tables reading..................... : Ok
Detecting ATA Overlay position...
Err> Terminal : reply timeout error
ATA Overlay (0)......................... : Error
ATA Overlay (1)......................... : Error
Error detecting ATA Overlay position!
Phase : Rebooting
HDD reply :
I want to recover the data if the hard disk then becomes burn o similar doesn't matter :D .
poehere
Re: Saving LDR from seagate
Postby poehere » 13.04.09, 08:46
Try to create a task in DE and clone the drive. If the drive will clone you can go ahead and get your data off the drive. If not then you will need to try and fix the problem with the loader
Choose only make a data copy then copy drive to another drive and see what happens
steven
Postby steven » 13.04.09, 13:43
it is problem with Overlay failed to load....
sometime it is PCB problem .. try to clean the PCB..
if still not help,... change Baud rate to 9600.. sometime it can read overlay with that baud rate....
manel
Postby manel » 11.05.09, 17:58
steven wrote:it is problem with Overlay failed to load....
Sorry for the delay!
It's not working :(.
Thanks!
manel
Thanks!
steven
Postby steven » 12.05.09, 07:57
what is the problem of this drive..
maybe you can tell us the FUILL report of terminal report.
manel
Postby manel » 14.05.09, 13:01
steven wrote:what is the problem of this drive..
I supose that will be a head problem. But It's imposible to find this HDD I don't know why. I've search throught all the world and no results found...
