ST3500320NS Barracuda ES.2 staying busy
mekaniq
Postby mekaniq » 17.02.09, 20:45
We have a ST3500320NS Barracuda ES.2 staying busy. We tried to solve this problem by same method as 7200.11 F3 architecture drives (LED problem + translator) but it does not work, can you please help asap?
datahelp
Re: ST3500320NS Barracuda ES.2 staying busy
Postby datahelp » 19.02.09, 12:00
We had similar problem with this drive. The drive was from hp PC with HP12 fw. We updated fw to Seagate one and it has solved the problem.
mekaniq
Postby mekaniq » 19.02.09, 14:36
This drive is also from HP server but with Seagate fw SN15. However, Seagate firmware update utility does not see this drive at all, so we were unable to apply firmware.
Pablo
Postby Pablo » 08.04.09, 11:18
datahelp wrote:We had similar problem with this drive. The drive was from hp PC with HP12 fw. We updated fw to Seagate one and it has solved the problem.
Hi Datahelp:
What firmware are you used to update drive?
poehere
Postby poehere » 09.04.09, 23:37
The new update is out, Maybe try to get them and install them. I see more drives now with the new update and drives with this problem before are now seen by pc3k. Check your download box for the new update or contract tech support direct. Install and then try again.
steven
Postby steven » 10.04.09, 10:39
pls put an update if the new update can do this JOB
Pablo
Postby Pablo » 15.04.09, 12:02
Hi!
I have a Seagate Barracuda ES.2 250Gb
ST3250310NS
fw: HPG1
The PC3000 recognizes it but with these parameers:
Model: ST_M13FQBL
Serial: QNR_BFW
Firmware: 11291209
Capacity: 3.86 Gb
Somebody have similar case? What can I do?
This drive have HPG1 fw, does PC3000 supports it?
steven
Postby steven » 16.04.09, 03:58
i think PC3Km ust support this drive,..
Change your Cable.. maybe it is because of bad contact or bad cable
Pablo
Postby Pablo » 17.04.09, 12:21
The cable is Ok. Thanks.
I see next:
the PCB disconect from HDA and conect to PC3000 shows the same parameters.
Another PCB form functionally same model disk disconect from HDA and conect to PC300 also shows the same parameters.
steven
Postby steven » 18.04.09, 03:55
is this only happen when u ataach it to PC3K...
How BIOS detect this Drive
Pablo
Postby Pablo » 21.04.09, 10:44
Hi Steven.
you're right.
When I attach this drive to PC, BIos detect it like: GB0250C8045 that matches to the HP MODEL.
steven
Postby steven » 22.04.09, 12:32
i think maybe this is something new for OEM Drive....
what is the model of this DRIVE...
GB0250C8045 0r ST3250310NS...
seem have double ID.. I dont think so
I ever see 72.10 Seagate with Model ST3250310AS.... Seagate NHAWKPLUS2HD... ST3250310AS Vs ST3250310NS...
maybe put a Pic is better
But very strange
Pablo
Postby Pablo » 23.04.09, 12:09
There's a picture of disk label.
This is an HP's PC internal disk, and have Hp firmware (HPG1) and own Hp parameters.
steven
Postby steven » 24.04.09, 09:18
first time see Drive with Double iD....
GURU
Postby GURU » 01.05.09, 15:57
Model: ST_M13FQBL
Serial: QNR_BFW
Firmware: 11291209
Capacity: 3.86 Gb
It's the default parameters for that PCB.. Much like WD M when you see something like
mammoth
s/n xyz
etc
