Hi to everyone ,
I dealing with one toshiba mk1234gsx which it was not spinning but i have change the pcb board and now is spinning without noises but i cannot have Drive id! Did anyone deal with this kind of HDD? Please advise me what shall i do! A! here is a little difficult to change BGA Chip!
toshiba mk1234gsx
Re: toshiba mk1234gsx
Over New Toshiba manual ace lab said its possible to did that task without exchange BGA, with UDMA, reading adaptive CP´s from patient and writting to donnor, i dont know if support u disk, but if u have tried to read u manual, wich are at u update box, should be there that new information
thanks for the advise i will check it!
compuman wrote:Hi to everyone ,
Did you check the fuse for damage? Usually this is big cause of damage to PCB in Toshibas, pretty simple fix also.
Only remove damaged fuse?
https://PrivateLadyEscorts.com - Live Streaming Chat - No Selfie - Anonymous [censored] Dating - Real Private Lady Chat
No. If fuse is damaged it needs either replacing, or removal and the connection needs to be bridged with some solder.
