Has anybody bothered to make a full list of WD family codes? Or is it available in some ware? It would be pretty useful to have since it does not actually read on the label that this is a Hulk and one needs it quite often when working with WD drives with PC-3000. Since it is easy to read the codes in them from model number there for example WD10EACS-00ZJB0 one can read the code so that in last part of the model number 00ZJB0 the middle letters ZJ are the letters that tells the family of the Drive.
I think it would be very useful to have a list like:
Scorpio LA WD1200BEVS-**LA**
Aspen FL WD Raptor 360GD-**FL**
Aries RS WD1600BEVS - **RS**
Hulk ZJ WD10EACS-**ZJ**
Etc.
In case anybody have this kind of list could you please share it with rest of us.
WD family codes?
Re: WD family codes?
It is available within the PCB layout feature and can be downlaoded from update box
Thanks,
I will check it out.
