I have a Seagate ST9320320AS, family 5400.5.
Drive gets ready, but shows no size.
In a regular PC, it's just the same.
Anyone had already some of these drives in and found anything about this problem?
Thanks.
Seagate 5400.5 family
Re: Seagate 5400.5 family
datalabace wrote:Hi,
Thanks.
Terminal works on 9600 or 38400 ? maybe this is F3 arch?
Who does not know anything, must believe in everything
Problem solved.
It's F3 Arch.
Thanks.
Problem solved.
It's F3 Arch.
Thanks.
Hi datalabace,
Can you share what you did to resolve your problem ?
I am having this one.
Code: Select all
Rst 0x08M
RW cmd 002F req = 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 18 F0 9F E5 00 00 A0 E1
opts = 00000000
RW Err = 84150180Re: Seagate 5400.5 family
Is the Translation Violation solution generic for all F3 drives, both 2.5" and 3.5"?
Roustam told-me that will not work.
Have you tried to regen translator ?
Give me your email.
Give me your email.
Give me your email.
me too please
thanks
The 5400.5 has the same technology as the 7200.11.
If doesn't work, maybe it's a new firmware that still has to be studied.
Have you tried hotswap?
I had a few of those, so I'm not sure about a specific case.
But depending if it's an important job or not, you should buy parts and try hotswap.
If you don't want to do that, I can try it for you.
Hi DataLab ACE,
The problem is not buy parts.
I can not find this one
ST9320325AS - 320GB SATA 5400.6 WU
Do you have it for sale ?
Jose
Jose
I don't sell drives, at least normally.
