Factory copy enable
Bruno
Factory copy enable
Postby Bruno » 05.01.09, 12:03
Dear all board users and AceLab Stuff. At the first time, i wish you all, a very happy new Year!
I can't find in the userguide of PC-3000UDMA, how to enable writing factory modules.
But i have two Hitachi HTS541 drives with the same problem RSVD 0 and 1 are ok, but the factory module can't be read. Only the factory Module RSVD and the DUMP Module are bad.
How i can solve this problem.
Thanks for any Help.
Bruno
dmarques
Re: Factory copy enable
Postby dmarques » 06.01.09, 14:17
Hi Bruno,
You don't need to.
That modules are always bad.
Have you tried to access sectors of the drive?
Bruno
Postby Bruno » 07.01.09, 11:34
Hi datalabace
zhank you for your engagement.
Yes now i tried, and have access. I read about 280000 sec. then i switched off the drive and connect a backup hd on channel 2. after start to copy sectors, i can't read any sectors... :(
what could bee, the problem?
Bruno
dmarques
Postby dmarques » 07.01.09, 16:02
Make SA test again and post the results.
Bruno
Postby Bruno » 07.01.09, 17:04
Dear datalabace
Your tip: make another SA-Test was helpfull!!
i comparing the new sa-test log with an earlier from the same HD and found difference.
Both modules OVR0 and OVR1 inthe earlier log has this entry:
mu-code................................. : C60R
and in the new log there are C6TR....
I also write the original Module OVR0 and OVR1 back to the Disc.
Now i can recover the data from this HD.
But why this entry has changed???
I dont touch it!!
Bruno
dmarques
Postby dmarques » 08.01.09, 09:48
Hi Bruno,
I really don't know why that change.
Had to analyse the case from the beginning to try to understand that.
Bruno
Postby Bruno » 08.01.09, 17:55
Hi datalabace
I think the key to the bad Modules is a moribund Head Preamp or ReadWrite-Channel.
I recover about 64'000'000 sectors, then the head make noises (clacking). That is enough, because on the drive are 10GB of data stored. :D I have all!
When i have more time, i try to analize them, but for the moment i have to do many urgent work. (Much HD and Memorycards to recover)
Thanks for help
Bruno
