WD5000AAVS - Head change
ZeBong
Postby ZeBong » 02.01.09, 17:54
Have change the head in this WD, but now i have the disk give DRD / DSC but dont have any info about the disk the model, serial, FW, size ?
PATIENT : WD5000AAVS-00ZTB0
DCM: HHRNNTJAHB
I just could find this model for head change:
DONNOR: WD5000AAVS-32ZTB0
DCM: HBNCHT2CH
Is any other problem here that i dont see ?
ZeBong
Re: WD5000AAVS - Head change
Postby AJ2008 » 05.01.09, 10:57
Im not 100% on this, but I always thought the 5th and 5th DCM characters represented Head and Preamp type? I know this is the case for older WD models.
If you do attempt this Head Exchange, please let us know how it goes.
Postby ACE_Admin » 05.01.09, 17:47
DCM: HHRNNTJAHB
TB letters stays for Tornado 3D drive. Unfoturnately this model is in development, and it is not listed in PC-3000 Utility supported families. However - you can try to access this drive by selecting similar families from WDC Marvell utility. If some family will be compartible it will succesfully read SA Modules directory.
Please let me know after you try it. I will also show this question to our developers to find out the solution.
I do not reccomend you to write anything to SA on this drive.
ZeBong
Postby ZeBong » 05.01.09, 18:01
I have change the heads for this model.
I get the DRD / DSC,
but dont have the disk ID, no size no serial....
what can i do with this heads is they match ?,
ZeBong
Mike_Montgomery
Postby Mike_Montgomery » 09.01.09, 11:43
I think the head swap has not worked. The ID information you are getting is from the ROM.
(Usually displayed something like <ROM Model>-<ROM Revision>-WDC-ROM SN# XYZ---
e.g.
WDC ROM MODEL-UNICORN---07.01D07-WDC-ROM SN# XYZ----
(the above was from a SABRE58 so your's may be different.
you will need a better head stack match.
Mike
Postby AJ2008 » 09.01.09, 11:51
Hi Mike,
Just from curiosity what is your success on head replacement on these drives?
