SAMSUNG HD501LJ 500G SATA, unable to access data please help
Moderator: Garry_TS
Nova
Postby Nova » 14.08.08, 06:12
SAMSUNG HD501LJ 500G SATA, detected normal under PC3000, unable to access data using DE. Checked firmware all ok. Reading service track gives error in head 0 and 1, the rest are ok.
Is there anyway to fix and get the data?
Thank you so much.
Reading service tracks
Into folder............................. : <HDD Profile>\Data\Tracks
Selected heads.......................... : 0,1
Read sector error (c: 0,h:0,s: 3)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:0,s: 4)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:0,s: 11)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:0,s: 12)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:0,s: 13)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:0,s: 14)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:0,s: 15)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:0,s: 16)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:0,s: 17)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:0,s: 18)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:0,s: 19)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:0,s: 29)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:0,s: 30)(PIO Mode data receiving timeout : device error detected (AMN))
Cyl : 0; Head : 0....................... : Read with errors
Read sector error (c: 0,h:1,s: 3)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:1,s: 4)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:1,s: 11)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:1,s: 12)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:1,s: 13)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:1,s: 14)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:1,s: 15)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:1,s: 16)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:1,s: 17)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:1,s: 18)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:1,s: 19)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:1,s: 20)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:1,s: 29)(PIO Mode data receiving timeout : device error detected (AMN))
Read sector error (c: 0,h:1,s: 30)(PIO Mode data receiving timeout : device error detected (AMN))
Cyl : 0; Head : 1....................... : Read with errors
dmarques
Postby dmarques » 14.08.08, 09:37
Have you tried to image the drive using DE?
Nova
Postby Nova » 14.08.08, 13:50
yep tried that, data is not visible, so tried R-studio but still nothing. thank you
zyzomus
Re: SAMSUNG HD501LJ 500G SATA, unable to access data please help
Postby zyzomus » 15.10.09, 09:38
I have the same problem with this drive, I would like to known what did you do to solve the problem?
Actually my drive has heads & SA OK, but cannot read data, the DE detect all partitions but no acces the Data!
I hope an answer of your problem!
N.C.
Postby N.C. » 15.10.09, 10:24
in this case i would test the heads inside the SA area, to be sure all are OK.
If the modules are all readable, try to send one soft reset after the first LBA access.
If still have problems, can you please show one terminal log from the LBA access attempt?
Janos
Postby AJ2008 » 02.12.09, 09:28
I think in many cases SA access is possible with damaged heads because of different densities of writing of SA area compared with data area. Did you try Soft Reset like Janos suggests? In many Samsung cases I have, I usually find hotwap method is very good in these drives.
