MAXTOR safe mode detect
ZeBong
Postby ZeBong » 30.06.08, 01:06
i Have 2 maxtor 80Gb sata, that when i connect tho the pc3k it start in safemode, and knoc knoc with some music.
Why the pck3 detect safemode
What is the general problem with this when they star in safe mode.
NOTE ( i see safe mode in red) but the motor is working, so the disk are not in really safe mode.
I Have also 1 disk 80Gb good from the same series.
Need to correct the other 2 to recover a RAID 5.
Jose
dmarques
Postby dmarques » 30.06.08, 11:51
Do you have the jumper set to safe mode?
If you don't have jumper set to safe mode, the motor spins.
ZeBong
Postby ZeBong » 30.06.08, 15:42
Yes i have the jumper in the adaptar in safemode.
When i give power the motor dont spin, is in safe mode,
Then i try to load the loader from database that i have a match donnor.
Them the drive start making noises clock, clock, clock.
And i can not upload the FW to the drive.
What can i do in this case?
Show some pictures.
Jose
dmarques
Postby dmarques » 30.06.08, 16:33
What's the initial problem of the drive?
ZeBong
Postby ZeBong » 30.06.08, 16:48
It makes clock clock and "sing".
i have two drives doing the same thing.
Jose
dmarques
Postby dmarques » 01.07.08, 11:08
Have you tried to check PCB?
If it's not a PCB problem, it's heads for sure.
ZeBong
Postby ZeBong » 01.07.08, 13:25
Yes,
I have change the PCB and, when i gove power it sound knoc knoc.
It´head ?
Jose
dmarques
Postby dmarques » 01.07.08, 17:27
Yes, it seems so.
Return to “Maxtor”
