Maxtor Daimondmax Plus 9 120GB Topic is solved
elgie
Postby elgie » 21.05.08, 13:13
I ahbe this 120 GB hdd. But it is configured in RAID0. I try to run partition analysis on it and it shows the data. But he problem is the data showing with data extractor is all corrupted. Is there anyway i can still recover data on it?? Thanks in advance
dmarques
Postby dmarques » 23.05.08, 10:21
If it's a RAID 0, you must have 2 drives and you must reconfigure the array so you can acess your data?
elgie
Postby elgie » 24.05.08, 08:30
is there a way to recover it wit data extractor??/
dmarques
Postby dmarques » 26.05.08, 10:06
No, DE doesn't rebuild RAID arrays.
You have to use another method, maybe manual.
elgie
  Topic is solved
Postby elgie » 26.05.08, 13:52
WHat could be the possible way to rebuild this?? or what could be the way so that we cen receover data on it?? im so helpless.. huhuhu...
dmarques
Postby dmarques » 27.05.08, 10:25
The way to do it is to find the parameters of the array and then use some application to rebuild it.
Return to “Maxtor”
