Hi guys
Need help on Maxtor 6E040L0510, it has module 18 (UBA 41) error and also Module 78, I tried regenerate but didnt work.
I can switch the drive to ALT-SA all modules are ok, and can I rewrite module 18 and 78 from ALT-SA to the faulty module 18 and 78?
Thank you for any help.
Maxtor 6E040L0 module 18 and 78 errors
- Alex Ivlev
You need tests->Service information->Work with service area->SA structure test, and send it to ts2@acelab.ru. What have you done with this drive?
Re: Maxtor 6E040L0 module 18 and 78 errors
I disagree. I think that module 18 and 78 will be repaired if you run tests->Service information->Work with service area->SA Surface Verification.
Then select Module Recovery from SA menu to repair PLIST (18). Then set to Master, disk should ID ok then run Translator Regeneration.
Alt SA (SA C) mod 18 and 78 are not appropriate for SA A.
If the drive can write its SA correctly (SA write test passes), U can try rewriting these modules to get rid of the reading error, then regenerate the translator.
if it doesn't work, I mostly use smart hotswap.
pepe
pepe
Nova wrote:Hi guys
Seems that the fault is with main SA not Alt-SA.
If SA Surface Verification fails, and modules cannot be written as pepe suggests, then HotSwap will be only way to get data back
i have the same problem ... for hot swap which module i need from the patient drive... all of them or some slected one ?
