Diamond Max Plus 8 (N40P) SA test OK, cannot read LBA
JiS
Postby JiS » 10.04.08, 10:05
how can I restore LBA access to Diamond Max Plus 8 (6E040L0) drive? It calibrates OK (HDD ID reading takes longer time), SA structure test is OK (except following):
Checking [DISK/PW]
Error ..................................... Wrong Module Id "93"
But when I try to access the drive by LBA i get readiness timeout (only the DRD DSC DRQ are ON)
I regenerated the translator but nothing has changed.
Thank you
PijoMax
Postby PijoMax » 10.04.08, 10:55
try repair the module in security - open HD
JiS
Postby JiS » 18.04.08, 09:14
The Wrong Module Id "93" error is normal for this drive type. It makes no problem.
There has to be something else why I cannot access the LBA.
Can someone Maxtor experienced user help?
JiS
Postby JiS » 18.04.08, 09:31
Oh, I can access the LBA now. Don't know what was wrong.
Return to “Maxtor”
