While using the universal utility to clone a SCSI disk, I did not see any settings for number of "retry". If I need to optimize the cloning of data (ie can go slower but want to copy as much data as possible), how do I configure the settings ?
The SCSI disk had lots of CRC errors.
SCSI Disk Cloning
Moderator: Sergey_TS
- Vladimir SCSI
Re: SCSI Disk Cloning
The quantity of hardware repetitions of reading can be set in command Mode Select (Tests-HDD Configuration-Mode Select Command) - Read Retry Count. This counter can accept value 1-255.
