Safe mode settings Topic is solved
Yuriy Manjilevskiy
Safe mode settings
Postby Yuriy Manjilevskiy » 13.08.07, 15:40
HDD's with DSP microprocessor: ATHENA DSP, ROMULUS DSP and others
PATA HDD's with microprocessor Poker, Ardent, Beagle and new one: ARES C64K, N40P and others
SATA CALYPSO HDD
To set safe mode, necessary to use PC-MXSAFE adapter without power cable connection and with "Calypso" jumper on it.
SATA HDD's Sabre, Sabre2, Grizzly, N40P, Shasta
To set safe mode, necessary to use PC-MXSAFE adapter with power cable connection on it.
redarrow
Postby redarrow » 30.10.07, 14:05
I currently own a PC-3000 PCI for Windows, i have ordered my PC-3000 UDMA but it may take several weeks to arrive.
I currently have a Maxtor 500GB SATA Disk detected only as Grizzly, i have a loader but i cannot load it as i am unsure on how to make start the disk in safe mode.
Any suggestions on how to do this on a Maxtor Grizzly SATA disk without the PC-MXSAFE adapter (the pc-3000 pci did not come with this).
Any help would be helpful as this disk i have at the moment needs urgent repair for data recovery.
Thanks.
Sergey Yatsenko
  Topic is solved
Postby Sergey Yatsenko » 04.02.08, 18:08
PC-3000 for Windows (non UDMA) can't correctly run loader on Grizzly drive. UDMA version can.
ACE Laboratory, PC-3000 Developer
cuumaytinh
Re: Safe mode settings
Postby cuumaytinh » 25.01.19, 06:24
i try but somtime it is not work.
Takanashi_Hina
Postby Takanashi_Hina » 25.01.19, 17:35
cuumaytinh wrote:Source of the post i try but somtime it is not work.
The original post goes back to 2008 ....
Return to “Maxtor”
