Seagate ST3160211AS sata problem
Vikas
Postby Vikas » 27.07.07, 08:12
Hello to all
I have a seagate which came to me as dead. I have changed the PCB with same model but it gives this error in terminal
Interface task reset
1024k x 16 SDRAM
TLITE - 1_Disk S-6B 03-22-06 10:53
Buzz - Head Mask FFFF - Switch to full int.
Spin Ready
ERR Read App Code
F>
What could be the problem. Need data
Vikas
Yuriy Manjilevskiy
Postby Yuriy Manjilevskiy » 06.08.07, 15:47
Dear Vikas,
Could you tell me what have happened with original PCB and what did you get at Terminal with it?
In case of PCB swap you have to rewrite/resolder ROM from original PCB to donor one.
Vikas
Postby Vikas » 07.08.07, 11:40
Thanks for the reply. it got burned. I think It will be solved by replacing ROM from it. Still pending as customer is not in the city.
Vikas
