Hitachi Travelstar HTS541040G9AT00
elgie
Postby elgie » 13.08.08, 11:34
I have this 40GB Hitachi Travel Star. When i start my pc3000, it is going to ready state mode but it cannot read the HDD ID I try to select the correct HDD ID but still same problem. I try to replace the hdd pcb. Anyone can help me?? Thanks
Igor
Postby Igor » 13.08.08, 15:14
Hello Elgie,
I would like to see your report.
Regards,
elgie
Postby elgie » 14.08.08, 08:27
Loading data for correction of HDD family handling settings from section DPTA
Selected family......................... : HTS541
Module not read (RESF)
Error : Device error detected (ABR)
Error :............................................................... : Module not read (RESF)
Module is not loaded (RESF, Main module table)
Module ZONE is not found!
narro
Postby narro » 19.08.08, 16:07
I think on 2 possibilities: PCB damage or pre-amplifier damage.
I have seen similar failures on this models. The drives spins up, but the spindle does not leave the parking area (it does not move). You can open it and check. Good luck
elgie
Postby elgie » 20.08.08, 08:11
what if the problem will be in pre-amplifier?? how can i repair it?? do i need to change any thing?? thanks
narro
Postby narro » 20.08.08, 15:26
If pre-amplifier is damage, you need you change the whole headstack....
Try first to transplat NVRAM to new PCB board.
