Hi all , i wonder if anyone has the modules , loader for following drive:
wd25EZRS-00j99b0
Techno mode key
Heads number............................ : 7
Cyl Count............................... : 192
Zone allocation table................... : HDDs RAM reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ROM version............................. : 20.1UP
ROM generation.......................... : 20.1UP
Link table version...................... : 0B.38.
Consolidated ROM version................ : 0020001U
ROM Modules:
Modules directory address............... : 283 719
SA regions address...................... : shifted
Heads number in use..................... : 7
Heads map............................... : 0,2,3,4,5,6,7
ROM Firmware version.................... : 0020001U
Weird case with drive sounding perfectly healthy but sits busy, then after a min ERR light pops up and we spin down . Changed PCB , moved ROM - same symptom. Changed heads - same symptom.
wd25EZRS-00j99b0 BUSY then ERR. No click.SA needed plz+ty.
Re: wd25EZRS-00j99b0 BUSY then ERR. No click.SA needed plz+t
Ended up not needing the donor. Used Aces advise ( Maxim Sorochinsky ) Work with RAM->DIR upload into RAM while in kernel mode. Got the SA access. Cheers all.
