Need WD10EADS-00M2B0 ROM version:00900014
happy2011
Postby happy2011 » 15.10.12, 10:26
hello
i have WD drvice spin motor not start
PCB bad.....
PC3000-UDMA ROM Recovery Fail...no 107 module...
I need WD10EADS-00M2B0 ROM version:00900014
Please Thanks you!
Re: Need WD10EADS-00M2B0 ROM version:00900014
Postby AJ2008 » 18.10.12, 13:50
Is PCB the only problem? Otherwise is healthy? Do you have full SA resources from patient HDD?
IF you save SA adaptives, it is possible to repair HDD with non-native resources (SA + ROM) from non compatible donor, then restore native adaptives.
p.s. I look, but dont have this version sorry
happy2011
Postby happy2011 » 19.10.12, 04:50
AJ2008 wrote:Is PCB the only problem? Otherwise is healthy? Do you have full SA resources from patient HDD?
thanks ! I have backup full(Cyl -49 ~ -170) tracks from patient HDD
Now how can I Recovery ROM from tracks??
