hello
i have WD drvice spin motor not start
PCB bad.....
PC3000-UDMA ROM Recovery Fail...no 107 module...
I need WD10EADS-00M2B0 ROM version:00900014
Please Thanks you!
Need WD10EADS-00M2B0 ROM version:00900014
Re: Need WD10EADS-00M2B0 ROM version:00900014
Is PCB the only problem? Otherwise is healthy? Do you have full SA resources from patient HDD?
IF you save SA adaptives, it is possible to repair HDD with non-native resources (SA + ROM) from non compatible donor, then restore native adaptives.
p.s. I look, but dont have this version sorry
AJ2008 wrote:Is PCB the only problem? Otherwise is healthy? Do you have full SA resources from patient HDD?
thanks ! I have backup full(Cyl -49 ~ -170) tracks from patient HDD
Now how can I Recovery ROM from tracks??
