How to turn off WD Marvell's heads in RAM
ZeBong
Re: How to turn off WD Marvell's heads in RAM
Postby ZeBong » 19.10.09, 11:51
Dobre will talk to you in messenger to help you out.
Pepe
Postby Pepe » 21.10.09, 03:50
I can help with WDs as far as head swapping is concerned or head selective copying, regardless of the model and architecture.
They are indeed tricky, but can be done.
Please feel free to contact me if you are willing to send the drive: info@adatmentes.net
pepe
patroclo
Postby patroclo » 27.10.09, 12:55
Hello everyone,
just to better understand, if we have this WD drive with faulty heads, should be better to replace them or not?
and by the way, if we couldn't replace them and have to turn off the damaged head, we should recalculate translator to get the data partially back?
I have a WD5000YS-01MPB0, after reassigned the head map, can access with data extractor and can see two partitions, but I can't acces the data. Any advice?
Thank you
dobrevjetser
Postby dobrevjetser » 27.10.09, 14:33
Always image what you can before replacing the heads.
With the Ace "Ram Head map" translator recalc is not neccessary.
Dobre
patroclo
Postby patroclo » 27.10.09, 17:14
Hi Dobre,
thank for your reply.
What I did is to swap heads.
patient: WD5000YS-01MPB0
donor: WD5000KS-00MNB0
Same behaviour, spinning, knocking, stopping!
So I made the procedure to get the ID of the drive. Got it!
Then data extractor with "make data copy" option enabled, then from menu Service---Building heads map, but after that when I try to access the root I still got ABR error.
This issue is driving me nuts!
Pepe
Postby Pepe » 29.10.09, 02:21
In fact I never use the RAM head map to gain access to data. It might be useful with the original heads, but as far as I hear, after head swapping it cannot always get things working...
pepe
dobrevjetser
Postby dobrevjetser » 29.10.09, 09:49
Yes, Ram head map should be applied with original heads.
Once they have been changed it is to late.
Dobre
jerk66
Postby jerk66 » 12.03.10, 18:26
Roustam
Is possible to disable a head with caviar32 WD2500PB
in my PC3000 UDMA menu "work with Ram" in kernel mode
i don't see the optin "ram head map editing"
Postby ACE_Admin » 07.04.10, 15:56
no it is not, unfortunately
Postby AJ2008 » 07.04.10, 17:15
As far as I know there is possibility to disable damaged head in caviar, then when you have good ID, reading system tracks and writing to donor will allow for data access after hotswap, assuming head map is built in DE from donor prior to hotswap. I have not tried myself, have not had opportunity, maybe if someone else tries they can write here to see how it goes.
Continuum
Postby Continuum » 07.05.10, 07:32
We also have a few drives here that show the heads map, but when you try the heads map changing in RAM, it says "Head map not found". How do we get it to find the heads map?
Postby AJ2008 » 07.05.10, 11:05
You may need to manually find the Head Map in RAM through 'Resources View and Edit' option.
Continuum
Postby Continuum » 12.05.10, 05:40
I can find the ROM version of heads map.
Where is the RAM version? Also, is there anywhere that specified the changes needed to be made? Is there a marvell manual out yet?
