I have a WD1600BEVE - 22WZT0 Which makes a sound as if wire were either breaking or hitting the top of the case. When
I ran PC 3000udma in McKinley mode I receive the following information:
Techno mode key:
Tech on................................. : Ok
ROM:
ROM version............................. : 01.09A
ROM generation.......................... : 01.09A
Link table version...................... : 01.27.
Heads number in use..................... : 3
Head map................................ : 0,1,2
Firmware version........................ : 00010009
Techno mode key:
RAM:
Zone allocation table................... : HDDs RAM reading error Techno CMD sending error Device Error Detected 51/04 (ABR)
Drive is not ready
SA SPT.................................. : SA SPT determination error Techno CMD sending error Drive is not ready
Head number reading..................... : Ok
Heads number............................ : 3
ROM:
ROM Data size........................... : 0 Kb
Service area:
SA dir reading.......................... : Unknown error. Code(0)
SA Copies avalabled..................... : NONE
Translator regeneration
Regeneration method..................... : Use P-List only
HDD Readiness timeout (10000 ms) D0 / 00
Heads test
Cylinder to test........................ : -10
Heads to test........................... : 0,1,2
Drive is not ready
Head 0.................................. : Error W : 1
Head 1.................................. : Skip
Head 2.................................. : Skip
Running DataExtractor I received the following
PC-3000 UDMA
The drive does not support LBA mode or the ID Drive was read incorrectly!
OK
What would my next step be?
Frank
WD1600BEVE - 22WZT0
- Towerrat79
WD1600BEVE - 22WZT0
Frank Meincke
Gefund-IT (Datenrettung)
Daimlerstrasse 70
74545 Michelfeld
tel: 0791-94 66 68 52
email: Info@Gefund-IT.de
web: www.Gefund-IT.de
Daimlerstrasse 70
74545 Michelfeld
Re: WD1600BEVE - 22WZT0
Hello Towerrat79,
The problem into this case should be in PCB.
You should to find a donor drive for HotSwap.
If you want to know more about HotSwap you can read our utility for Western Digital 8.4 HOT-SWAP method.
REgards.
REgards.
- Towerrat79
Igor
Thank you for the reply. For my knowledge, where did you see that the PCB should be the component that is causing me problems?
Frank
Frank
Frank Meincke
Daimlerstrasse 70
74545 Michelfeld
Daimlerstrasse 70
74545 Michelfeld
