I got ST3000DM001 3TB drive. spin ok and recognize in the Pc3k... after a while /// in terminal give errors below ...
Write Error - C4090081
(DOS) Write Failure Reallocation started.
(DOS) AutoWriteReallocationEnabled and Reallocation Request Issued. !00000080
(DOS) WriteFailureReallocateLBARequest is executed successfully.
(DOS) Write Error - C4090081
Anybody have some solution for this ?
ST3000DM001
Re: ST3000DM001
Can you save SA?
Can you access sectors?
Can you save SA?
Re: ST3000DM001
can not access sector , and SA
Re: ST3000DM001
But can you even access terminal?
Re: ST3000DM001
On the most drives reading channel line is crossed with an element,
so it is easy to find two lines that go from pads to CPU on your drive board.
You should short the contacts with a pincers when holding a paperclip with it.
Also, the moment to short is before 2nd recalibration.
When shorted properly, drive will start to click and then it will stop.
At the same time press ctrl-z within terminal window and check if T> is there.
Re: ST3000DM001
Often, if you are patient you will reach some access to SA and sometimes data. At this time you can disable any pending parameters.
If not, then follow Dima's advice and try to find short points.
