7200.9 - 3.AAE - ST3808110AS Unable...
rcz
Postby rcz » 14.09.10, 14:41
This drive has "Unable To Load Ovl 01..." problem.
I didn't managed to start it with a loader as when I put it in safe mode, leds are switched off. In fact it seems that safe mode is activated as I can read via terminal but Utility produce an error when passing in safe mode.
I've read 7200.9 3.AAE had head problems so I try to change head but nothing change.
Is there a tip for this case ?
rcz
Re: 7200.9 - 3.AAE - ST3808110AS Unable...
Postby rcz » 16.09.10, 15:40
When I want to read ROM, Utility tries to iniitialize safe mode, and almost all leds are reds... So I have error that ROM couldn't be read...
I have the same problem with a working drive... Why ?
erick
Postby erick » 29.10.10, 02:52
Could ou post the full terminal Log?.. i have a similar problem but some times works whit some commands.
rcz
Postby rcz » 29.10.10, 08:07
I haven't got this disk anymore. Thanks.
Postby AJ2008 » 29.10.10, 14:20
There is alternate data access method that can be made in such case were T> is possible. But access is very slow :(
