Seagate st2000dm001 2TB - preampfaultstatus =0000YW
Arihant
Postby Arihant » 29.05.14, 17:30
I have Seagate 2Tb hdd st2000dm001 Remains busy. Motor spin ok and running, No clicking noise. Check with the other pcb but problem remains same.
Terminal output.
Boot 0x40M
Spin Up
RECOV Servo Op=0100 Resp=0005
TCC-0026[0x00026F7C][0x000270DF][0x000270DF]ZZZZMMMMMMMMMMMMMMMZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZZMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMMddddddW
PreampFaultStatus = 0000YW
PreampFaultStatus = 0000YWMMMMMM
What is the mean by 0000yW preampfault?
Thanks,
Amit Shah
Arihant Data Recovery, India
drmilos
Re: Seagate st2000dm001 2TB - preampfaultstatus =0000YW
Postby drmilos » 12.08.14, 03:52
Hi Amit,
have you found a solution for this problem?
I have the same problem with same model after head stack replacement - terminal output as Amit posted.
Anybody else with a solution?
Arihant
Postby Arihant » 12.08.14, 08:15
I doubt in Rom corruption or Head adaptives. What is the usage of Block-1 and Block-2 option in rom for SAP+RAP+IAP Modules change in Ram?
Thanks,
Amit Shah
shomyl
Postby shomyl » 02.10.14, 20:11
Arihant wrote:I doubt in Rom corruption or Head adaptives. What is the usage of Block-1 and Block-2 option in rom for SAP+RAP+IAP Modules change in Ram?
Just wash the PCB and do short pointing for access terminal
already did on 2 Drives with same preampfault error.
Arihant
Postby Arihant » 04.10.14, 13:50
I have check with other pcb (rom Swapped).
Still same problem.
Is any other check points ?
Thanks,
Thanks,
Amit Shah
