Need Loader for WD5000AAKS - 22A7B2
Francois
Postby Francois » 25.06.10, 18:19
To All who can help:
I need a Loader for WD5000AAKS - 22A7B2 urgently.
below are results from log:
Techno mode key
Flash Dir reading....................... : Ok
ROM version............................. : 05.DGE
ROM generation.......................... : 05.DGE
Link table version...................... : 04.AL.
Heads number............................ : 3
Heads number in use..................... : 3
Head map................................ : 0,1,2
ROM Firmware version.................... : 000500DG
Re: Need Loader for WD5000AAKS - 22A7B2
Postby AJ2008 » 01.07.10, 16:40
This log is made from disk in Kernel mode. Can you access SA? Does spindle stop?
If disk powers down it is likely the fault is with physical components, heads maybe. If power is constant, possible may be SA damage.
If spindle stops, then LDR is of no use im afraid.
Francois
Postby Francois » 07.07.10, 16:47
Thanks for the response.
The disk however does not power down therefore i am thinking LDR will help me.
Please anyone.
Francois
Postby Francois » 29.09.10, 19:07
SO no one can help me? It has been quite a while and this is a very important case. Sigh.
dmarques
Postby dmarques » 04.10.10, 11:00
I have something here that might be of any help.
Here it is:
http://rapidshare.com/files/423023271/W ... 663590.rar
dataLAB
Postby dataLAB » 15.10.10, 04:39
Are you still looking.
I have WD5000AAKS - 22A7B0 01.03B01
Does that help? If so PM me your email.
Users browsing this forum: Baidu [Spider] and 11 guests
