Timeout of waiting NAND chip readiness.
Posted: 09.05.17, 16:52
I have 32Gb SDHC card. I found the pin layout from the site and soldered on circuit board.
Now the Flash tools detect the chip Id Perfectly.
[09.05.2017 20:34:04]: PinState ID= 8 ->
[09.05.2017 20:34:04]: .. Bus= 8 bit/ IO0x-0 -> ID= 0x453C9693 (ID EXT= 0x453C9693 7E570904) - OK! Parts detect... 1 OK! 2 Fail!
[09.05.2017 20:34:10]: For current chip ID= ID= 0x453C9693 (ID EXT= 0x453C9693 7E570000) pinout scheme is = 9.
[09.05.2017 20:34:14]: Chip ID= 0x453C9693 (ID EXT= 0x453C9693 7E570904)
[09.05.2017 20:34:29]: Microchip ID =00 PATH =01:
while creating the dump of chip it gives error.
[09.05.2017 20:46:44]: R/#B0 -> 0 -> Status Line FAIL!
[09.05.2017 20:46:44]: Status line is in 0 state.
[09.05.2017 20:46:44]: It maybe damaged or havn't contact .
[09.05.2017 20:46:44]: It's recomended to change check status on by command.
[09.05.2017 20:46:47]: NUD:NRP-> Error(3)!
[09.05.2017 20:46:47]: NUD:NRP-> Error(4)!
[09.05.2017 20:46:47]: Error in Nand Page reading. (Page: 0 )
[09.05.2017 20:46:47]: *****************************************
[09.05.2017 20:46:47]: Error!
[09.05.2017 20:46:47]: Error type:Device error!
[09.05.2017 20:46:47]: Error code:Error of working with memory chips.
[09.05.2017 20:46:47]: Info:Timeout of waiting NAND chip readiness
The error is continuesly. reading chip data shows totally 00
How to resolve R/#B0 status line fail error?
Thanks,
Thanks,
