Sandisk Ultra microSD 32GB
jerovsek
Postby jerovsek » 08.06.20, 07:03
I try to recover files from this card. If I try to read with PC3000 SD adapter, I can recover some files with row recovery, but all files are corruped.
When I try to recover with spiderboard, pinout check is OK, but when I try to read ID I receive R/B fail error.
Pinout for this card is 4x6 type 2
Any sugegstion
Thank you
Re: Sandisk Ultra microSD 32GB
Postby Roman_TS » 08.06.20, 09:49
Hello. Please make a ticket in ts.acelab.eu.com
Our engineers will guide you.
jerovsek
Postby jerovsek » 08.06.20, 10:43
Hello Roman,
ticket is already opened(28.5.2020), but no response from TS
Best regards
Jure
Postby Roman_TS » 08.06.20, 16:17
I will pick it up. Sorry for delay in our response. It was a fault of our engineer.
jerovsek
Postby jerovsek » 09.06.20, 13:30
Thank you Roman.
Everything is OK.
Postby Amarbir[CDR-Labs] » 16.06.20, 20:08
Did you solve this buddy ,Jerovsek can you share id and mcu of this
jerovsek
Postby jerovsek » 17.06.20, 06:48
Hello Amarbir,
case is not solved, because controller block access to the nand
arvika
Postby arvika » 15.08.20, 10:59
jerovsek wrote:Source of the post Hello Amarbir,
It is not true :) I have many same cases, where other reader can read dump correctly.
Postby Roman_TS » 20.08.20, 14:11
As an option you can solder GND wire from Spider to A1 pin in Pin Map Scheme 1 for mSD. It should help to block access of CPU to the NAND core. Usually help.
http://www.pc3000flash.com/solbase/mono ... 4&lang=eng
Postby Amarbir[CDR-Labs] » 18.09.20, 06:26
Jerovsek ,
Did you try what roman said ? . Roman i do not think that should work BTW reason it Main Pins are fully connected to NAND VCC then it will never make a difference .
DXR
Postby DXR » 08.06.24, 18:19
Roman_TS wrote:Source of the post As an option you can solder GND wire from Spider to A1 pin in Pin Map Scheme 1 for mSD. It should help to block access of CPU to the NAND core. Usually help.
Hi All...
At the "Read Chip ID" stage, I had the same "R/B Fail" error on a SanDisk 2GB mSD (type 4 monolith) - This was my very first attempt at monolith recovery...!!
...I tried what Roman suggested, soldering 0.2mm wire from GND on spider to pin A1.... and it worked!!
Regards Jason
