Samsung MZ-VKV512 950 Pro
Posted: 03.12.16, 19:51
by oldman
Just hope that someone got idea for this SSD drive, it is detected, just can not access the data area. Look some firmware problem, but pc-3000 does not support it.
Thanks.
Phil
Re: Samsung MZ-VKV512 950 Pro
Posted: 11.12.16, 06:29
oldman wrote:Source of the post Just hope that someone got idea for this SSD drive, it is detected, just can not access the data area. Look some firmware problem, but pc-3000 does not support it.
Thanks.
Phil
Hello Phil ,
Roman would be the guy to ask for this ,you could also post in flash section of hddguru and see if a expert could help you
Posted: 14.12.16, 11:46
by Roman_TS
Hi all!
950 Pro will appear in support list in 2017 I suppose.
Posted: 04.01.17, 01:03
by oldman
Hi Roman and Amarbir,
Thanks for your reply.
Does Samsung 950 Pro has the same problem as 850, with encrypted terminal?
Wonder why ACE lab does not provide me the M2 Key M adapter, I ordered and only received the Key B, or key B+M adapter, are there any ways to read the Key M?
Thanks.
Phil
