The Kingston Flood - UV300 Series
Posted: 30.04.16, 12:26
by Amarbir[CDR-Labs]
Hello Roman ,
India Is Flooded By This Kingston UV300 Seris Drive .I Personally Have The 240GB Installed In My Computer .When Will PC 3000 SSD Support This SSD ? .
Re: The Kingston Flood - UV300 Series
Posted: 02.05.16, 08:59
by Roman_TS
It's a new generation of Kingston SSD based on Phison S10 controller if I remember. We already continue our developing in this type of CPU, and soon we will add a lot of Phison based SSD. The good thing is that Phison based SSD are very stable and it's not easy to kill them
Posted: 03.05.16, 07:19
Roman_TS wrote:Source of the post It's a new generation of Kingston SSD based on Phison S10 controller if I remember. We already continue our developing in this type of CPU, and soon we will add a lot of Phison based SSD. The good thing is that Phison based SSD are very stable and it's not easy to kill them
Hi ,
This is Good NEws ,But They Have TLC NAND Is That Not Bad Enough ?
Posted: 03.05.16, 09:02
by Roman_TS
Yes, it's true - Kingston UV300 contain TLC NAND which have bad quality. But controller PS is very good - it can make a lot of additional optimization with data, and reduce wearing of the NAND cells.
Posted: 05.05.16, 12:42
Roman_TS wrote:Source of the post Yes, it's true - Kingston UV300 contain TLC NAND which have bad quality. But controller PS is very good - it can make a lot of additional optimization with data, and reduce wearing of the NAND cells.
Hi ,
When Will The Tool Be Updated With this Controller ?
Posted: 06.05.16, 09:56
by Roman_TS
Hope that during next 3-6 month. New Utility will include a wide support of Phison based drives, that's why developers need more time before they will release it.
Posted: 18.08.16, 13:13
by dobrevjetser
Hi Roman,
When SSD equipped with TLC are bad, is it a good idea to put them in a fridge to slow down the rate at which the memory disappears, until you guys come up with a solution ?
I suppose the hotter the chips are stored, the quicker they lose their contents ?
Marc
Posted: 18.08.16, 18:10
by Roman_TS
dobrevjetser wrote:Source of the post Hi Roman,
Marc
Hello Marc. Don't worry about that - information on this SSD will stood safty for several years. We found problem with cells charge floating only in Samsung 840 EVO
- It was one of the first massive TLC-based SSD with problems.
Posted: 07.12.17, 19:41
by MasterT
I also have a Kingston HyperX Savage 240gb SSD for recovery and has Phision PS3110-S10 CPU.
Do you have any ideea if and when this CPU will be supported by PC3000?
Thank you.
Posted: 08.12.17, 08:52
by Roman_TS
Next Monday 11.12.2017 solution will be available for all customers who have active TS on PC-3000 software
Posted: 09.12.17, 03:53
Roman_TS wrote:Source of the post Next Monday 11.12.2017 solution will be available for all customers who have active TS on PC-3000 software
I know what is coming love you roman
