Apple 2013+ SSD 12+16 pins adapter
Posted: 12.10.18, 13:00
by SlingShot
I'm trying to find a way to connect this via SATA.
I've got the 12+16 pcie to USB board but cant interface that with the 3K or the DDI4.
I've got the 12+16 pcie to m.2 but the notch is in the wrong place for m.2 to sata
Is there a way to do it or am I at a brick wall here ?
Re: Apple 2013+ SSD 12+16 pins adapter
Posted: 15.10.18, 12:04
by Roman_TS
Hello SlingShot,
There is no connectors for SATA. Starting from 2013 Apple is using PCIe bus instead a SATA. Inside controllers of SSD, SATA block is not presented. That's why it's useless to look for a APPLE to SATA adapter starting from 2013.
The only way - try to find PCI-E adapter and insert it in your motherboard PCI-E slot.
https://www.ebay.com/sch/i.html?_from=R ... E&_sacat=0
Posted: 18.10.18, 12:45
by SlingShot
Roman_TS wrote:Source of the post 2013 Apple is using PCIe bus instead a SATA. Inside controllers o
Roman_TS wrote:Source of the post Hello SlingShot,
OK thanks Roman, this will only work for software though. The only way using hardware appears to be using the SSD add-on with the DDI4.
Does Acelabs have any plans so these can be used on the 3K ?
Posted: 19.10.18, 17:11
by Roman_TS
SlingShot wrote:Source of the post Does Acelabs have any plans so these can be used on the 3K ?
Yes, in future we are going to present the best solution in the market.
Posted: 19.10.18, 19:42
by SlingShot
Roman_TS wrote:Source of the post SlingShot wrote:Source of the post Does Acelabs have any plans so these can be used on the 3K ?
That sounds exciting, looking forward to it
Posted: 13.11.19, 11:09
by SGdata
Any news on "the best solution in the market"?
Posted: 13.11.19, 11:35
by Roman_TS
You even can't imagine how close this news to our news line
Posted: 13.11.19, 12:53
by SGdata
Try me
That would be a big update.
Posted: 13.11.19, 17:01
by DataMedics
I really hope it's just an add-on that can be used along with PC-3000 + SSD, and not an entirely new system to buy
Posted: 14.11.19, 06:39
by bikram
Hi All,
We also require Mkey To SATA converter please help
Posted: 14.11.19, 12:11
by Roman_TS
It's impossible to read PCI-E or NVMe drives through SATA bus. It's two different interfaces with complete different number of transferring commands.
