Hitachi HTS545032B9A300 INIT prob
Posted: 15.06.16, 11:11
by emir_has
I have HTS545032B9A300 and when i start autodetect i get this info pic error1.
Also I have read the text from knowledge base of acelab web site but i cannot go to techno mode
Please help I am kind new in this bussiness.
Re: Hitachi HTS545032B9A300 INIT prob
Posted: 15.06.16, 14:38
by Vikas
What are the symptoms when you power the drive.
Posted: 16.06.16, 09:27
by emir_has
When disk start it clicks few times but quietly and status registers are up DRD and DSC. And when I hit autodetect or tried manualy error register is up and ABR register is up, no hdd id.
Posted: 16.06.16, 19:29
by msurgeon
You are using the wrong utility. This disk is supported in Hitachi/IBM utility under custom families.
Posted: 18.06.16, 09:54
by emir_has
I found the model in custom list but still no HDD ID. What to try next?
Posted: 18.06.16, 09:59
by emir_has
Here is new logo window with errors
Posted: 19.06.16, 13:00
by emir_has
I have found almost same model of the disk (Hitachi HTS545032B9A300-PB3OC60N-100410PBN3001TJX414R)
I have made resource backup of this disk. This disk on sticker on PCB has only last letter in second line different then my damaged drive.
Then i tried to put his NV-RAM on my damaged and i have succeeded also i tried to write ROM on my damaged disk and succeeded. BUT I CANNOT get HDD ID!!!!
Can someone help please?
Posted: 21.06.16, 11:47
by emir_has
Here is my log what I get when I tried HDD ID. Please can someone give me some instruction what i can try next.
******************** 21.6.2016 11:51:50 ********************
Loading data for correction of HDD family handling settings from section MEM_P
Loading data for correction of HDD family handling settings from section HTS5450B9
Selected family......................... : CUSTOM
Model by ID............................. : <ID IS NOT READ>
NV-RAM reading.......................... : Ok
Module not read (RESF)
Error : Device error detected (ABR)
Error : .............................................................. : Module not read (RESF)
Module ZONE is not found!
Module is not loaded (RESF, Main module table)
Test : Reading NV-RAM
Reading NV-RAM to file ( C:\Program Files (x86)\ACE Lab\PC-3000\Bin\!Profiles\HITACHI-IBM\CUSTOM\Melika\Data\NV-RAM\NV-RAM.nvr )
Reading................................. : Ok
Saving.................................. : Ok
Test : NV-RAM adjustment (SA search)
To vary.................. : SA Top
from..................... : 0x28334
to....................... : 0x2EB34
Working folder........... : C:\Program Files (x86)\ACE Lab\PC-3000\Bin\!Profiles\HITACHI-IBM\CUSTOM\Melika\Data\NV-RAM adaptation
RAM reading............................. : Ok
Searching for SA Tops table image in RAM : Error
Test : Reading modules
Reading modules to profile folder (composite)
Folder: C:\Program Files (x86)\ACE Lab\PC-3000\Bin\!Profiles\HITACHI-IBM\CUSTOM\Melika\Data\Modules
Module not read (RSVD)
Error : Drive not ready
Drive not ready
Drive not ready
Module RSVD............................. : Error
Error : ModStg: composite reading impossible - reading error!
Drive not ready
Drive not ready
Drive not ready
Drive not ready
Module RESF............................. : Error
Modules reading completed
Test : HDD configuration changing
Module IDNT is not found!
Test : Clear S.M.A.R.T.
S.M.A.R.T. Enable Operations Error Device error detected "ABR"
Clear S.M.A.R.T....................................................... : Error
Device error detected "ABR" 51 / 04
Soft reset ...
Soft reset ...
Posted: 21.06.16, 18:26
by msurgeon
More than likely the heads are the problem here.
Posted: 11.10.16, 22:13
I just had a HTS725032A9A364 come in today returning this exact same error message. No clicking, got ready really quickly, but no SA access, can't read modules directory, etc.
Changed heads, and am now imaging at 104Mb/s.
Posted: 09.11.16, 16:24
by Filipp_TS
msurgeon wrote:Source of the post More than likely the heads are the problem here.
DataMedics wrote:Source of the post I just had a HTS725032A9A364 come in today returning this exact same error message. No clicking, got ready really quickly, but no SA access, can't read modules directory, etc.
Yes, basically it's a Heads issue.
But sometimes drive has been in other DR lab (before your) and now it have a not original PCB...
So, one more little trick is check S/N in NVRAM editing window and compare it with S/N on the HDD label. :wink:
