DT01ACA050 MS1OA8A0
gmdata
DT01ACA050 MS1OA8A0
Postby gmdata » 28.11.17, 02:57
I had HDD DT01ACA050 MS1OA8A0.
This HDD recognized PC3000.
capacity size and sectors is very good.
I could read succeed modulus and SA.
but I can't read data area.
I tryed changed RDMT, PSHD and "Initialize Translator in RAM".
Could you some adviced for me?.
Sergey_TS
Re: DT01ACA050 MS1OA8A0
Postby Sergey_TS » 28.11.17, 14:26
gmdata, did you check SA modules? You can attach log here, I will take a look :wink:
Postby DataMedics » 28.11.17, 21:13
gmdata wrote:Source of the post I tryed changed RDMT, PSHD
What exactly do you mean by "changed RDMT, PSHD"?
gmdata
Postby gmdata » 29.11.17, 02:12
Thank you. Sergey_TS and Data medics.
I send log data. I think that modules is good.
I tryed to write RDMD, PSHD from Another HDD' RDMT, PSHD.
But HDD was same. Can't read Data area.
20171129 PC3000 myoungseong 2.png (57.57 KiB) Viewed 11116 times
20171129 PC3000 myoungseong.png (145.42 KiB) Viewed 11116 times
Sergey_TS
Postby Sergey_TS » 30.11.17, 17:16
gmdata, SA looks OK here.
gmdata wrote:Source of the post I tryed to write RDMD, PSHD from Another HDD' RDMT, PSHD
It was a bad idea, because these modules are unique for every drive. Hope you backuped them. :shockable:
Please write them back!
Please check if all critical modules were uploaded into RAM (Sercvice Objects --> RAM) :!:
Is your drive with single head :?:
Postby Amarbir[CDR-Labs] » 01.12.17, 03:01
Sergey ,
This Drive is Single Head IMHO
gmdata
Postby gmdata » 04.12.17, 03:26
Thank you. Sergey_TS and Amrbir.
The backed up file was written to the original HDD.
The head has one. I confirmed it on PC3000.
Sergey_TS
Postby Sergey_TS » 04.12.17, 10:10
gmdata, Most probably it's head degradation in your case, but did you check content of RAM as I mentioned before?
gmdata
Postby gmdata » 13.12.17, 02:12
How do you check the data in RAM?
This hard is a firmware 8A0,
It is difficult.
Please let me know how to check the head ... Thank you.
