ST1000LM024 can read in sector edit but not DE
osity
Postby osity » 18.03.17, 18:28
What would cause the drive to be able to read sectors using "sector edit" in the utility but not in DE?
In DE I just get readiness loss error.
Re: ST1000LM024 can read in sector edit but not DE
Postby Amarbir[CDR-Labs] » 22.03.17, 04:10
Osity ,
Try To Set ector Read To 1 In DE In Your Case With Lower Read Speeds
osity
Postby osity » 22.03.17, 19:17
Amarbir,
If you mean block size. I've tried that with no luck. I've also tried read timeouts as low as 60ms
Postby Amarbir[CDR-Labs] » 23.03.17, 03:52
osity wrote:Source of the post Amarbir,
Kindly disable head map in DE and then try might be it works also try pio mode " hardware tries " .Very Unique Problem BTW .
osity
Postby osity » 23.03.17, 14:55
I've tried PIO as well. Do you mean disable all heads in DE? Not sure how that would work, :)
Postby Amarbir[CDR-Labs] » 04.04.17, 15:53
osity wrote:Source of the post I've tried PIO as well. Do you mean disable all heads in DE? Not sure how that would work, :)
Well,
Read What i Said "I am Saying Do Not Create a Head Map " Just Try Like This and If You Have Created Head Map Deselect That Not Deselect Heads
osity
Postby osity » 04.04.17, 19:17
what does "If You Have Created Head Map Deselect That Not Deselect Heads" mean?
How would you disable the headmap after creating it without creating a new task?
Return to “Spin Point”
