Boot ROM Mode - Schematics For 2.5" SATA Interface
Blizzard
Re: Boot ROM Mode - Schematics For 2.5" SATA Interface
Postby Blizzard » 15.12.16, 05:47
Hary wrote:Source of the post All WD 2,5" USB drives (not slim)that has pins on PCB in two raws including this one from topic can be connected using Toshiba adapter as on attached picture
and this new L or as You wish J shape PCB can be connected via soldering 3 cable
:D
Yes, thank you for sharing this information.
Postby Amarbir[CDR-Labs] » 15.12.16, 15:48
Well ,
i got the adapter only now but i still use toshiba adapter,The WD 2.5" adapter helps well in recovery of dead pcb in 2.5" using boot mode
Maxim_TS
Postby Maxim_TS » 30.01.17, 14:10
Friends, I've added the new WD USB manual in update boxes, there are some new pictures for adapter connections and terminal connection presented.
Blizzard
Postby Blizzard » 30.01.17, 14:42
Got it! Thank you.
drdoc
Postby drdoc » 03.04.17, 18:51
heres a really easy way to connect serial port
solder two pins
and connect ribbon cable direct
viewtopic.php?f=155&t=7397&start=30
[urlhttp://forum.acelab.eu.com/download/file.php?id=842&mode=view][/url]
skype: wayne_horner
Alandata Data Recovery
300ddr
Postby 300ddr » 03.04.17, 18:57
Very cool Wayne! Thanks for sharing!
O.S
Postby O.S » 19.02.26, 19:18
Maxim_TS wrote:Source of the post Amarbir[CDR-Labs], WD 3,5" and 2,5" adapters are availabve for purchasing. Everyone can contact ACELab sales managers to get those adapters.
Please past an image for it >
