need help for wd10jmvw-11s5xs1
ictsec.areait
Postby ictsec.areait » 25.05.17, 16:49
I connected wd10jmvw-11s5xs1 by USB and serial cable and I got the following errors:
Expand view Displayed errors
Techno mode key
Debug Stop Code reading................. : VSC Status reading error Data receiving error COM port reading timeout (rq: 523 / rd: 0):
HDD Info reading........................ : HDDs RAM reading error VSC data reading error Sectors receiving error Data receiving error COM port reading timeout (rq: 515 / rd: 8 ): BE EF 01 00 00 00 12 40
Zone allocation table................... : HDDs RAM reading error VSC data reading error Sectors receiving error Data receiving error COM port reading timeout (rq: 515 / rd: 8 ): BE EF 01 00 00 00 12 40
Read ROM................................ : HDDs ROM reading error VSC data reading error Sectors receiving error Data receiving error COM port reading timeout (rq: 515 / rd: 8 ): BE EF 01 00 00 00 12 40
Service area:
SA dir reading (ABA/CHS)................ : Device error detected
Collapse view
Spindle motor starts and no weird sounds.
Is the board broken?
Thanks in advance
Re: need help for wd10jmvw-11s5xs1
Postby Amarbir[CDR-Labs] » 26.05.17, 12:19
Hello ,
Remove board from HDA assembly .Then Connect To USB and Serial Cable Wait For 5 Minutes Then Run USB/Serial Western Digital Tool .Select Kernel Mode From Mode Selection on top ,Then Please Post Result Here .Once if it reaches kernel mode properly backup complete rom and also rom modules .Please tell me the USB pcb no so that i can assist you further
ictsec.areait
Postby ictsec.areait » 26.05.17, 19:49
Isolated board works better, no more ROM and RAM errors.
Expand view kernel mode output
Techno mode key
Debug Stop Code......................... : HOST DEBUGSTOP UNEXPECTED HBI INTS UNMASKED
Modules directory address............... : 73 265
ROM Modules:
ROM version............................. : 03.78C
ROM F/W version......................... : 00030078
Overlay F/W version..................... : 03.78C
Servo F/W version....................... : TP.4D
Collapse view
Board number is: 2060-771801-002 REV A
Postby Amarbir[CDR-Labs] » 26.05.17, 20:08
Hi ,
Next Step Do You Have 771823 Sata PCB
Maxim_TS
Postby Maxim_TS » 30.05.17, 19:22
ictsec.areait, there are several ways to work with USB drives, read more here:
http://blog.acelab.eu.com/if-you-ar ... rives.html
Return to “WD USB”
