WD usb decrypt - the 2 ways
hddr49
Postby hddr49 » 27.02.15, 17:22
Hi guys,
I'm here with a WD usb drive. Crap...
Until recently I don't have last version of DE, so I couldn't use on the fly decrypt.
During this time, I sucessfully clone most part of th usb drive with a sata board.
So I got drive image... crypted.
Now, I have last version of DE.
Can I decrypt my crypted image with software otf decrypt?
Mount task as drive, something like this ?
I started to clone again with decrypt, but last time it take 3 weeks, due to large amount of errors...
Thanks for help and ideas
hddr49
Re: WD usb decrypt - the 2 ways
Postby hddr49 » 03.03.15, 15:56
I add an info :
original usb PCB seems well working. It is recognised in WD usb utility and I can work with.
hddr49
Postby hddr49 » 06.03.15, 14:56
ok, there is what I have done :
- copy sector-by-secor image file to another hard drive (WD)
- initiate disk in WD Marvel utility
- create new DE task, check decrypt, use file 25.rpm from original drive to have key.
Now I have access to data (thanks to Maxim from TS)
Greetings,
Maxim_TS
Postby Maxim_TS » 24.11.15, 13:29
hddr49, Thank you! You and other customers are always welcome in ts.acelab.eu.com !
Return to “WD USB”
