How to make a com-port connection with WD USB drive
Re: How to make a com-port connection with WD USB drive
Postby Amarbir[CDR-Labs] » 23.02.17, 04:20
DataMedics wrote:Source of the post Exactly. And even with the SATA boards, I never bother with a ground and it works too. Probably because it's getting the ground from the SATA power cable.
He He ,
Good catch by me on this one
drdoc
Postby drdoc » 02.03.17, 05:17
better way to connect terminal port on 800041 board
this is easier just add 2 pins to the board and connect...
you dont need ground, aces adapter doesnt use ground.
the toshiba adapter 1 pin offset method has no ground.
the maxtor calypso adapter to the 3.5 wd only uses 2 wires.
skype: wayne_horner
Alandata Data Recovery
Postby Amarbir[CDR-Labs] » 13.03.17, 05:43
100% if my electronics experience serves me correct ground is needed ,Its just that its being used by power connector like conventional on sata hods and usb one from modern usb drives .How about totally isolating the device from the same pc as pc-3000 and trying just rx,tx pins i am sure its not gonna work .
Postby DataMedics » 16.03.17, 19:46
Amarbir[CDR-Labs] wrote:Source of the post Well,
It might. If both computers are grounded to the same electrical system. I don't know about there in India, but here every structure built or renovated in the last 50 years is fully grounded. So generally something like a com connection will still work because all devices ultimately are sharing a common ground. They just need that same common point of voltage reference.
Now if you ran one device off a generator or a UPS that's unplugged it wouldn't work for sure.
Postby Amarbir[CDR-Labs] » 23.03.17, 03:55
Jared ,
If We Have a Laptop on the other end without being connector the power its on a different ground plane .GND is necessary for such connections
Postby DataMedics » 29.03.17, 01:12
Who is using a laptop to do professional recovery? This is Ace Forum, you can't plug a PC-3000 into a laptop generally.
Postby Amarbir[CDR-Labs] » 02.04.17, 08:54
DataMedics wrote:Source of the post Who is using a laptop to do professional recovery? This is Ace Forum, you can't plug a PC-3000 into a laptop generally.
I Use ,
I have 1 Mac , 2 New Core i3 Asus ,1 Core i5 Asus Ultrabook And 4 Old Once ,I was giving you a example how ground can be totally isolated .PC 3000 Portable is a Pro Tool For Laptops BTW
betty
Postby betty » 22.01.18, 08:29
hi
anyone can show how to make USB to SATA connection of WD 4 tb model:WD40NMZW-11GX6S1 AND PCB no is : 2060-800041-003 REV P1 .The pics of the PCB given in the same post. i am not able to find out the 4 PF which i need to remove . I can see the E71,E72,E73 and E75. But in the inside portion there is no reference marking of PF.
Any one have idea plz lead me.
Betty
Maxim_TS
Postby Maxim_TS » 01.03.18, 16:34
betty wrote:Source of the post i am not able to find out the 4 PF which i need to remove
Expand view
Collapse view
drdoc
Postby drdoc » 26.06.18, 01:44
Contrary to my previous position....
I have found difficulties reading the roms with just 2 pins.
I used alligator clips and grounded the board to the computers chassis
And then I could read without issues.
So - yes you do want the ground.
Maybe before it was grounded through the usb power, not sure but use the ground.
skype: wayne_horner
Maxim_TS
Postby Maxim_TS » 06.08.19, 16:31
Paulfromsurrey
Postby Paulfromsurrey » 13.10.19, 07:38
I am trying to copy the rom from usb wd drive to sata compatible board
is there is any better documentation we can find somewhere
Here is the connection for WD USB 2.0 drive:
Image ((((No Image))))
Hard drive has 6 pins in one row. So, PC-Toshiba adapter is connected, and three pins are left free(((which 3 pins left or right)). Please check the picture above.
Here is the connection for WD USB 3.0 drive
Hard drive has two rows of 6 pins. PC-TOSHIBA adapter has to be connected onto top row. The drive position has to be same, it is on picture.((((No Image))))
As soon, as new manuals for PC-3000 WD USB utility will be ready, it will appear in personal update box, manuals Western Digital section.
Paul Patil
PC Plus Computing
Data Recovery Services
Business IT Services and Computer Repair Services
https://pcpluscomputing.com/services/Da ... -Services/
pclab
Postby pclab » 15.10.19, 12:53
Try with Samsung Terminal adapter too.
Maxim_TS
Postby Maxim_TS » 23.10.19, 14:01
Paulfromsurrey wrote:Source of the post As soon, as new manuals for PC-3000 WD USB utility will be ready, it will appear in personal update box, manuals Western Digital section.
This type of connection is already described in WD USB manual from customer's update box. WD 2,5" terminal adapter is recommended to use.
Return to “WD USB”
