Is the WD30NMVW-11C3NS2 supported?
Filipp_TS
Re: Is the WD30NMVW-11C3NS2 supported?
Postby Filipp_TS » 09.11.16, 16:19
protech wrote:Source of the post Hi Guys,
Got a couple of case of these drives WD20NMVW-11C3NS2 apparently with similar problem. Was able to solder a SATA connection so now the drive gets to DRD DSC.
But as soon as i try to enter utility it gets BSY and stays there. Like ThomasH said head isolation is not working. I assume the drive has a slow responding issue, is there any other way to tackle it?
You can shorting the reading channel on the PCB when you switch on the power supply it's also get a Kernel mode as result.
protech
Postby protech » 09.11.16, 16:58
Hi Filipp,
Its a pleasure to hear from you 8) . How can I find the read channel and at what stage do I short the read channel. I am also waiting for the new COM port connectors for WD. So am I screwed or can it be done?
Maxim_TS
Postby Maxim_TS » 15.11.16, 10:58
protech, try to isolate the head contacts and run the utility in Kernel mode to get ROM access.
Then block module 02 access in Work with ROM menu (it is necessary to use v6.2), power off the drive and remove the isolation.
Start the drive in Kernel again, and go to Work with RAM->Upload Dir and loader into HDD RAM menu.
Load the Dir and loader from same ROM fw version backup folder, reenter in utility in Normal mode and you can work with SA.
murtazabawa
Postby murtazabawa » 15.11.16, 17:22
Hello Everyone,
Kindly provide the read channel to short on 800022 pcb.
I have replaced USB to SATA + ROM but doesnot autodetect. Remains BSY on isolating PCB contacts.
Thank you all in advance. :)
Best Regards,
Murtaza
Data Recovery Dubai
Maxim_TS
Postby Maxim_TS » 13.12.16, 09:59
protech, try to block the access to module 02 in PC-3000 v6.2.20, and then load Dir and loader from backup to RAM. Then follow the Slow Responding and SED procedures.
drdoc
Postby drdoc » 13.02.17, 09:15
Model : WDC WD30NMVW-11C3NS2
Serial : WD-WXC1E25D0PY3
Firmware : 01.01A01
Capacity : 2 794.49 GB (5 860 467 633)
This drive came in with a bad board.
Swapped rom.
Can access SA and data.
HD id says sed locked
scan and map defects scans fine.
gets the error perm overlay not loaded on startup.
4096 sector drive.
picked model big bear
sw version is 6.0
drive detects under winxp
and I can read blocks
ram head map editting didnt work.
skype: wayne_horner
Alandata Data Recovery
Marek
Postby Marek » 09.06.17, 09:25
Where is it on the new PCB's place to shorting channel in WD30NMVW???
Postby digitalsupport » 09.06.17, 15:49
Sorry but what do you want to short?
Return to “WD USB”
