WD USB Decryption is Password protected ...HELP
goooz
Postby goooz » 14.10.16, 09:52
who can help me to solve this Password Problem??
lcoughey
Re: WD USB Decryption is Password protected ...HELP
Postby lcoughey » 14.10.16, 16:13
Easy...ask the client for the password.
Marek
Postby Marek » 14.10.16, 16:21
If client forgot password? :)
goooz
Postby goooz » 14.10.16, 18:18
never set any Password...
lcoughey
Postby lcoughey » 14.10.16, 20:08
Are you able to fully clone the drive without read errors?
Postby Amarbir[CDR-Labs] » 15.10.16, 13:51
lcoughey wrote:Source of the post Are you able to fully clone the drive without read errors?
Sir ,
Assuming He Is What Is Your answer Then And Assuming It Isn'nt Then Whats The Answer
Postby DataMedics » 16.10.16, 01:30
Amarbir[CDR-Labs] wrote:Source of the post
Sir ,
I think what Luke's suggesting is that the key sector near the end might not have been read properly. I've had at least one case where that sector was bad.
Postby Amarbir[CDR-Labs] » 17.10.16, 13:58
DataMedics wrote:Source of the post
Sir ,
Might Be Can Reverse Clone Some Portion of Patient
Maxim_TS
Postby Maxim_TS » 21.10.16, 09:31
goooz, try to solve the Slow Responding, then connect the original USB PCB. If it also requires the password, it's the bug of INIC1607E and it can not be solved.
Such bug puts some LBA from user area to key module.
einstein9
Postby einstein9 » 13.11.16, 10:14
Maxim_TS wrote:Source of the post goooz, try to solve the Slow Responding, then connect the original USB PCB. If it also requires the password, it's the bug of INIC1607E and it can not be solved.
Dear Maxim, i have to disagree with you here, but IT IS POSSIBLE and CAN BE SOLVED.
Thank you
Maxim_TS
Postby Maxim_TS » 15.11.16, 10:51
Dear einstein9, I've heard about the donor modules for such cases, but never tried this method since I have no such cases here last month.
As soon I try it, I will let you know.
Return to “WD USB”
